| OFF-ROAD FORUMS | | Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation. | Sponsored Links | | Jeep-Full Sized All discussion of full sized Jeeps: Wagoneer, Full Size Truck |
08-18-2003, 11:22 PM
| | | Valve rocker setting Just rebuilt a donor 360 for my CJ 5 and I have some top end ticking which I believe is play in the rockers or it sure sounds like it.Does anyone know what is the recomended procedure for setting adjustable stock rockers in a 360. Getting zero lash is no problem but I'm not sure what the additional turn down on the rocker nuts should be.
Thanx
[img]images/graemlins/40BEER.gif[/img] |
08-19-2003, 08:44 AM
|  | Super Moderator | | | Join Date: Dec 2001 Location: Belleville, Illinois
| | Re: Valve rocker setting Here's how we did it on SBC engines: First we'd get the engine warm, then remove a valve cover. With the engine at a slow idle we'd back off an adjusting nut until it started clicking, then turn it down until the clicking stopped, and then go one turn farther. The engine would bog a little as that valve was held open for a few seconds. After the lifter bled down and the engine returned to normal idle we'd do the next one.
It was messy, with oil splashing all over and dripping onto the floor, but it seemed to work fine. Later a speed equipment company marketed little spring steel clips that went onto the rocker arm over the oil hole. They didn't stop the flow of oil up the pushrod, but kept it from squirting out onto the fenderwell.
I can't say if that's the procedure for the AMC V8, but it should work if you can't get any better advice. |
08-19-2003, 08:43 PM
| | | Re: Valve rocker setting Thanx for the info Jim. That's basically the procedure I used for the initial start up, But I still have the clatering noise. [img]images/graemlins/confused.gif[/img] If I go a full turn past zero lash, I get valve floating like you said, but it dosn't go away. I am going to try a half turn rather than a full turn and see what happens.
There is another procedure with the engine shut off.
Bring # 1 cyl. to compression stroke @ TDC (Make sure timing mark on harmonic balancer is @ TDC mark. 0 degress)
Then set valves to zero lash. (turn push rod back and forth while turning down rocker nut until push rod will no longer turn freely- Zero Lash)
With # 1 cyl. @ TDC You can set Intake valves # 1, 2, 5, 7.
Exhuast " # 1, 3, 4, 8.
Turn crank 1 Complete revolution to TDC ( # 6 cyl. )
You can then set Intake # 3, 4, 6, 8.
Exhuast# 2, 5, 6, 7.
For a small block Chev. You turn the rocker nuts down an aditional 3/4 turn after you achieve zero lash. This is suppose to put the lifter pistons in the middle of there stroke.
Again, I'm not sure what the additional turn down should be for AMC 360 rockers?
08-19-2003, 09:39 PM
| | Addict | | | Join Date: Dec 2002 Location: Minnesota
| | Re: Valve rocker setting if they are bridged (stock bridged) then just tighten them to 23ftlbs | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | Off-Road Videos - Check out over ten years of extreme 4x4 action,
product testing and the Off Road Nation at play. Baja racing to rock crawling, ATVs in the sand to motorcycles in the dirt, it?s all here. Rate them, share them and upload your own. | ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | In the Business of Off-Road?- If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com! | All times are GMT -5. The time now is 12:13 AM. |
