V8 On-Board-Air I'm planning to install On-Board-Air on a Jeep CJ with a 360 V8 from a '72 J-20. I've seen an A/C setup available in a salvage yard on a Wagoneer with a 360. The compressor was missing the top bracket & the bolt on the top side that I believe is the oil level inspection port. I also noticed that two belts drove the compressor and alternator. To accommodate this, the fan/water pump & crank pulleys each had three belt grooves; the other groove to drive the PS pump. I'm sure the two belts are there to handle the normal load of running A/C.
My engine only has two belt grooves on the fan/water pump & crank pulleys & a single groove on the alternator.
I plan on at least buying the alternator brackets (& possibly the alternator) as I have verified that they are different than mine (to support the bottom of the A/C bracket). I have purchased a set of A/C brackets & a York compressor.
I'm looking for information/suggestions on running the setup on one belt or buying the fan & crank pulleys? Any idea what's involved in pulling the crank pulley (haven't verified how it is attached)? I'm going back to the place next week & will try to negotiate a total price. I may even need to get the PS bracket depending on the offset. Its easy to see that my engine was never setup for A/C.
Thanks |
