Hey wiz, sounds like your havin fun.Wish I had a plasma cutter, I just had to use a sawzall. Did you check out where I put my tranny coler? Its a slimline cooler from summit.It shouldnt be too hard to find a junked Wagoneer, they'er a dime a dozen around hear.I went ahead and put mine in spring over for lift and I didnt even have to move the spring perches, the rear bolted right in.I even got the Zu Ebrake cables to work on it. Just had to get an adapter to hook the metric brake line to the sae rear brake hose and it was done.I wouldnt recomend usin the ZU rear, the ujoints are way to small aand would be easier to beef your driveshaft if you could go to a bigger ujoint.I used the shaft out of the waggy and it fit perfect, no cuttin.
You can post some pics at the same place mine are,Webshots. they dont charge anything.
See ya, RB
