ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > IH Scout & Trucks
Old 06-21-2009, 07:58 PM
Newbie
kevdog is on a distinguished road
Default ignition problems
Hello
Another new(and proud) guy here. I have a 1976 Terra with a 196 cid 4 speed. I've read many of the chats online and several situations seem similar to mine but I would like to share my situation. My Terra starts and runs 99.9% of the time. It runs puurrrfect....
Every 1 out of 50 times it decides not to start. Not a sound. Got lights, Got gauges, but not a sound. The first occurrence Terra had been sitting for about 10 mins since it was driven. I waited another 10 mins and it started. For the next 50 starts NO problems. Then again after about an hour drive I left the truck and returned in 10 mins. Not a sound, No nothing. After a dead key for about 30 mins I got out and reached down to jump the starter and it spun. Tried the key again, Not a sound. I was in hilly Westwood ca so I rolled the truck down the street and popped the clutch. It started and has been starting ever since and running great. I not a real ignition guy but it appears to be updated with some electronics. The starter is shielded but my first thought was "HEAT" since it started after 10 mins the first time but on the second occurrence it sat for over 30 mins and did not start. It only started when I popped the clutch. I would appreciate any and all suggestions. Also looking for a stock radio for the 1976 Terra.
Thanks Kevin
Old 06-24-2009, 02:32 PM
Newbie
baldscout is on a distinguished road
Default
Sounds like your solenoid is starting to go. It is overheating and is in need of replacement. It is a "Hot Start" issue, the Ford Solenoid conversion will get you back on the road without worry. Do a search on "hot start" over at binder planet and you'll get more information than you'll need to do the conversion. Posts by BillUSN-1 will be most helpful.
Old 07-05-2009, 09:44 PM
Journeyman
garscout is an unknown quantity at this point
Default
Try the ignition switch on the steering colum first.if it starts at the starter....and it starts half the time with the key......i would try the switch before anything. It's pretty much a standerd gm switch the bolts right to the base of the colum.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
