OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > IH Scout & Trucks
Old 10-09-2007, 10:30 PM
Stranger
skijorer38 is on a distinguished road
Default ignition resistor 64 scout Help
Help,
I am confused. I recently purchased a 64 scout 80 and the distributor was torn apart. I found the parts to put it back together but when i went to NAPA they sold me a coil with an ignition resistor (little white part) When I look service manual I also see a picture of the resistor but when I look at the wiring diagram it shows a resistor used with a generator but not an alternator. My scout has an alternator. My questions are 1. Do I have the right coil ? Do I need this resistor? Also to note in the wiring diagram it shows for an alternator that the ignition switch wire must be 72 inches it seems if I add this resistor it will mess up that resistance.
Please help I really want to get this rig running
thanks
JH
Old 06-07-2008, 08:43 AM
Stranger
Shoehorn is on a distinguished road
Default
The resistor has absolutely nothing to do with your alternator.
The resistor is supposed to be in the +12v lead to your coil to cut it to 6v. It's a points thing. Basically, it will make your points last a hell of a lot longer. Do you need it? No, not really. I ran without one for 2 years, but I changed points 3 times. Without the resistor, you can gap your plugs to .040 or .045, which will be better for performance, but it's going to be a headache on the points. I would recommend using the resistor, and gapping you plugs to .030.
I would also check to make sure you don't have a resistor wire in the harness before you use it.
If you do have a resistor wire, get that garbage out of there. It's nothing but trouble. It gets hot, and it's bundled up with a bunch of wires you really don't want to burn.
The ballast resistor you have there is a much better option. Just screw it to the firewall, and run your wire to the + side of your coil through it before it gets to the coil.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
