OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > IH Scout & Trucks
Old 09-24-2007, 03:17 PM
Stranger
MR95gst is on a distinguished road
Default Ignition control module
Has anyone ever heard of bypassing the icm. I recently got another scout and it was running fine for awhile. Now Im having trouble getting spark. It will fire up and run for about 5 min. and then it wont start due to lack of spark. If you wait for about 2-3 hours it will start back up again for another 5 min. The original icm is still mounted on the firewall, but not connected. There is a 12v source coming from the ign. to the positive side of the coil and from the negative side of the coil to the distributor. Is this an effective way to wire the engine. Thanks in advance for any help.
Old 06-16-2008, 06:28 PM
Stranger
Shoehorn is on a distinguished road
Default
Need pictures.
Old 06-22-2008, 10:54 PM
Aprentice
heavyequipment is an unknown quantity at this point
Default
It seems someone has replaced the more modern distributor with an older one, with points and a cam. Make sure the point contacts are clean and smooth, and that the point gap is correct (check tune up guide for a '72). If all that is OK, maybe the coil has an intermittent break that opens up with heat. Also, if the coil is made to run with a ballast resistor and doesn't have one, it will burn the points pretty quickly.
I did the opposite, replacing the breaker point ignition on my '72 Scout II with a more modern electronic ignition, which usually needs much less maintenance than the older stuff.
Good luck
__________________
Don't force it - - get a bigger hammer!!
Old 06-30-2008, 02:28 PM
Stranger
Default
Quote:
It depends on the distributor you have. Not all scouts have a icm, actually, very few have one. My 74 for example has a holley curved points distributor.
If you are running without it at all, you don't need it. Pics would really help. Your points, condenser, coil, resistor are the key points, and all happen to be very cheap.
  #5
Old 06-30-2008, 02:32 PM
Stranger
Default
And while you are in there, stand the coil up. Running a canister type coil on it's side is VERY bad for it. They are ALL designed to be mounted vertically, and there's plenty of room to do so, even in the stock location.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
