ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Standard SFA Trucks & SUV's
Old 06-22-2009, 08:54 PM
Newbie
kaelshort is on a distinguished road
Default Little help on My Build
Hey all im new to the forum and figured id get some opinions on what front and rear end i should go with, and how big of a lift i should go with, i have a 1980 suburban body on a 86 frame, atm i believe it has a 4" rancho suspension lift(thats what the guy i bought it from told me) its the 1/2 model with auto 350 in it. My plan is to run some 37-38s on it(so i can be bigger then my buddys blazer :P) and just wondering what the best set-up is gonna be best, its not gonna be a dd so i dont care much about fuel milage, just whats gonna be good in the mud. Also if i was just gonna run 35s what would be the best option for me to go? Thanks for all and any help!(also looking to spend the least amount possible)
Old 06-24-2009, 09:36 AM
Novice
Gator is on a distinguished road
Default
On my 82 K10 I had a mix match lift... 6 inch lift springs up front. 4 inch springs in the rear and a 3 inch body lift. I had 35s on it with plenty of room to clear 38s. The factory set up for all K series trucks is that the front end sits 2 inches lower than the rear. This is the reason i lifted the front of mine 2 inches more than the rear. it sat perfectly level and didn't nose dive.
The front springs were around $250 from superlift.
You could save money and just use blocks in the rear.
Body lifts are usually less than $100
NEVER use lift blocks to raise the front of your truck.... It's deadly!
Old 06-24-2009, 10:47 PM
Newbie
Default
ok sounds good, that seems like the easist way to do it, how can i tell right now if i really have a lift right now or not? deff looks like theres blocks in the back, so ill got measure that, maybe ill luck out and just have to get new springs in the front and do the body lift. heres a pic. what gears are you using in yours? also was wondering if front and rear bushing kits are necessary?
Old 06-25-2009, 11:45 AM
Novice
Default
looks like you have a 4 inch lift already on it... you should be able to clear
35's as is. as far as gears i ran a 3:73 and it was a little sluggish in the bottom end of the powerband. if you run 35's i would recomend 4:11 gears for everyday use or step up to 4:88 if you do alot of towing or wheeling
  #5
Old 06-25-2009, 09:09 PM
Novice
Default
BTW suburbans are kick ass.... 4X4 suburbans are even better
  #6
Old 06-26-2009, 07:33 PM
Novice
texas sub is on a distinguished road
Default
looks pretty healthy, don't forget to upgrade the brace stearing box. igot a 90
texassub
  #7
Old 06-26-2009, 09:05 PM
Newbie
Default
yeah atm it has some 373 gears ill proably keep them in there till they go, then ill proably be switching to some 4.88 gears and one ton axles so i can turn some 38s, i plan on going to the store tomorrow and ordering a 3inch body, cuz im getting my 35s on monday and rather be a little higher anyways for them on there also i was wondering if anyone knows what color of wire is the gas gauge wire coming from the wiring harness in the engine bay, long story shorts they guy before me threw a newer body on there and didnt connect anything, so i got a pink wire going from the gas tank, and i dont know what to connect it to, found a yellow wire hanging on the frame by the wheel well in the front, could that be it? any help is appreciated
  #8
Old 06-28-2009, 12:27 AM
Novice
Default
good call on the steering brace... The frame behind the steering box is very weak... mine cracked just from normal daily driving with 35's... When you install your body lift you need to extend your steering shaft also. if not you'll have too much stress on it and it can fail without warning causing a nasty situation if your in traffic ... as far as axles the stock half tons will hold up to 38s on pavement providing you don't abuse them. Then again its always better to be safe than sorry... steer clear of the 8 lug 10 bolt front axle when you upgrade. Its really nothing more than your stock front axle now, just bigger brakes and 2 extra wheel studs
  #9
Old 07-02-2009, 01:23 AM
Newbie
Default
hmmm k sounds good, so anyone got any idea on that wiring? or know a place online with all the vehicle wiring?
  #10
Old 07-06-2009, 12:12 AM
Novice
Default
checking on it, son's got an 86? not sure if it helps? also the body lift might be a problem, they like to twist in a bind. new ones might be better? some where in the old pages of this site theres a guy who has the ratios for gears/ tire ratio. i haven/t found it again. if you hav a pic on the wires might help, son has gone to bed.
Tags
suburban
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
