dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | GM Standard SFA Trucks & SUV's All discussion of full sized Solid Front Axle Trucks, SUV's to include Suburban |
03-15-2009, 06:08 PM
| | Journeyman | | Join Date: Nov 2002 Location: Spokane Valley,WA
| | Blazer w a 6.2L diesel
Hi all. Im usually on here for my jeepster but am thinking on buying a blazer with a 6.2 liter diesel. I do not know much about this motor but would like some input if anybody has any.
Thanks
Matt
__________________
71 commando
used to be 225/T400/D20
Soon to be 350/SM465/NP205
poor short fat white kid
03-20-2009, 08:25 AM
| | Keyboard Implanted | | Join Date: Jan 2001 Location: Mountain Home Idaho
that motor is pretty much junk. but i think it would be kool in k5 crawling around burning desel. it should work well just doesnt have much if anymore power than the 350 gasser
__________________
K5 fabbed everything, welded 10bolts, sm465, hydralic clutch. 1 tons waiting for 10bolts to grenade. 35" boggers. most the glass is broke out, no straight sheet metal, seems to be on its side as often as its not
02 cummins dualy tow rig, all stock for now, cept for a BHAF. exaust next then a chip n were done.
03-22-2009, 11:30 PM
| | Novice | | Join Date: Jan 2009 Location: slaton texas, on the bottom of panhandel
all the 6.2s that i've seen playing around,they don't last long. never had one. i have seen one up in boise id. power train swaped for gas ,original axels and brake/power steering setup. it was diehard, and mean.
mike
03-23-2009, 01:39 PM
see my hood emblem. ive noticed quite a few 6.2s in blazers around here. though mine is running a 350 with TBI heads and carb intake everything else is stock but she runs very well with the carb feeding tbi heads.
__________________
03-29-2009, 12:40 PM
|  | Mud in my Veins | | Join Date: Mar 2000 Location: Traverse City, Michigan
| | The Diesel Page - for the 6.2L, 6.5L, and Duramax 6600 (6.6L) GM Chevrolet and GMC diesel engines.
The folks there and on the diesel forum on Colorado K5 - Full-Size GM 4x4 Restoration and Off Road Community can tell you quite a bit about them. They're good engines and will last a good long time getting great mpg if you take care of them.
That said they aren't and never will be a Cummins, Duramax, or Powerstroke. A lot of folks think they were supposed to be big power towing motors and they aren't. They were meant to be great mpg replacements for GM's most common engine in it's trucks in the early 90's...the small block V8. Similar levels of power as a factory carbed SBC while getting at least half again better gas mileage and sometimes double.
__________________
86 Chevy K30 M1008 CUCV. Big, beefy, 6.2L diesel and NATO forest camo on 1" lift and 38's.
'89 Chevy Blazer K5. 6.2L diesel, stockish and liking it. DD/puppy wagon. |
05-05-2009, 07:59 PM
| | Stranger | | Join Date: May 2009 Location: Champaign, Illinois
| | Quote:
Originally Posted by AJMBLAZER | Just thought I'd echo this. I have a wheelin' buddy that's got a 6.2 diesel, and what you said is pretty much the truth.
05-10-2009, 04:21 AM
|  | Veteran | | Join Date: Dec 2000 Location: Fort Rucker, AL
Andrew has posted a good reply. If you take care of the engine: change the oil, put good fuel in it, and replace the glow plugs if they are bad, and keep the cooling system in good shape(hmm, sounds llike what you would do with any engine, except the low plugs) it will be a long lasting engine that is predictable, easy to maintain andreturns good fuel milage.
My 6.2 has 74,000 miles on it. It is in a 6700lb, 1990 suburban with 39.5' bias ply Iroks and a 1 ton drivetrain with 5.13 gears(it does have OD). I pull 15 miles per gallon consistantly. My big block powered truck that weighed a little more than the sub only got 7-9 mpg and most any small block in my truck would maybe get 12 mpg.
Botom line: If you want a good running engine that gives good mileage, the 6.2 is it.
__________________
Drey - "might as well try...with enough duct tape anything is possible"
07-09-2009, 08:20 PM
| | Novice | | Join Date: Jul 2009 Location: new york
I hope this still counts. Well, my brother had one and he said that really, it's a good engine. Gives you good mileage although it runs only for a short time. it's like it'll exhaust all that it can, give you the umph, but it'll quickly get tired.
____________________________ short block |
07-09-2009, 08:29 PM
Sounds like somebody who never took care of their diesel.
There's plenty of us with well over 100k on ours and they run just fine.
__________________
07-09-2009, 08:35 PM
Oh, hmmm, I'll ask him again. He just observed that from his friends.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 03:12 PM. |
