How to set timing on a tbi motor? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Standard IFS Trucks & SUV's
Old 02-12-2001, 08:30 PM
BigMan
Default How to set timing on a tbi motor?
I have a 92 chevy with a 350 in it. I need to know how to set the timing on this thing since it has the computer controlled advance. Any help is greatly appreciated.
Thanks
Old 02-12-2001, 09:19 PM
dave's Avatar
dave is an unknown quantity at this point
Default Re: How to set timing on a tbi motor?
Usaully the underhood engine decal will show how to time the engine. Now having said that, I know that a 9 year truck might not have the engine decal. Here is what I can say, use a jumper wire between pins "A"(ground) and "B"(test) of the ALDL connector. Then set the timing to 6 degrees BTDC. Remove jumper.
dave
Old 02-12-2001, 10:01 PM
k2500454
In the wireing loom near the dist. thier is a single brown wire with a connector hanging out of the loom just disconnect it and start the motor and set your timeing then shut it down and re connect the connector
Old 02-12-2001, 10:09 PM
on the passenger side, under the dash, is a taped cluster of wires. the aldl connector is there. Disconnect it. Then, start the truck, and adjust the timing. The check engine light will come on, just disconnect the negative cable, and it will clear out. Reconnect the ALDL connector before restarting the engine. I wouldn't go over 2+ degrees, it will ping unless you put 92 octane in it. If you put an aftermarket chip in it, it will ping worse.
Rhino
  #5
Old 02-12-2001, 11:39 PM
The decal under the hood says to disconnect the brown wire from the loom near the Dist (mine is between the dist and master cylinder)...unplug it...start the truck, set the timing...shut it off, and reconnect...should be pretty simple once ya get to pokin' 'round...JD
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
