1/2 ton / 3/4 ton dana44??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-16-2000, 06:01 PM
can anybody tell me the difference between a dana44 from a 1/2 ton and one from a 3/4 ton??? i am looking to upgrade but i was wondering if a dana 44 from a 3/4 ton would be beefier than that out of a 1/2 ton. i dont wheel that hard and i dont use 4 wheel drive that much.
MUDD_RAT: 1978 Chevy K-10 with dana 44 front, 12 bolt rear 350/350/203 running 15/39/15 Mickey Thompson Baja Belted
post #2 of (permalink) Old 11-17-2000, 02:59 AM
Re: 1/2 ton / 3/4 ton dana44???
The only difference is really the fact that the 3/4 ton ones are 8 lug. The stuff that is different is related to that. The brakes are a little bigger, basically they're different from the knuckles out. A 3/4 ton 44 is no beefier than a 1/2 ton one. If you're installing an 8 lug rearend, do a 3/4 ton 44 just so the lug pattern matches, if you're using a 6 lug rear, use a 1/2 ton 44 for the same reason.
<font color=green>Evan</font color=green>[img]/wwwthreads_images/icons/crazy.gif[/img]
Shaggy is offline
post #3 of (permalink) Old 11-17-2000, 07:13 AM
so there is no difference from the 1/2 ton to the 3/4 ton exept the lug. the shafts are the same size and the ring and pinion are the same size.
post #4 of (permalink) Old 11-17-2000, 11:42 AM
Basically yes, there is no difference between the gears and axleshafts in a 1/2 ton or 3/4 ton Dana 44......except for some early '70s versions with externally splined hubs and smaller u-joints. The 10-bolt started showing up in the late '70s and also has a 1/2 and 3/4 ton version, which are basically the same except for the 6 lug or 8 lug, but are different then the Dana 44's. Everything from the knuckle out should interchange (hubs, rotors, spindles) but the axleshafts and gears/carriers are different between the 10-bolt and Dana 44, though similar in strength.
6.2Blazer
Human Verification
