MPG@ 9! GMT800 Tahoe 2000 5.3 4x4 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-11-2011, 04:20 PM Thread Starter
Newbie
bowtie4by's Avatar
I get 9 mpg after moving to Florida. I was getting 16 mpg in Arizona with A.M. temps at 70 degrees; A.M. temps in FL are 40 degrees. Oil is 0-40 Mobil1. AZ driving was 15 miles each way on the freeway 5 days each week; Florida is stop and go for 1-3 miles, with some 100 feet elevation changes. Air filter is clean. No codes. Tires at 70 psi. 3.73 rear. Not towing; not doing the stop-light-drags. Wassup?
bowtie4by is offline
post #2 of (permalink) Old 01-19-2011, 09:19 AM
Shorts's Avatar
Possible winter fuel blend. Idling and acceleration hit engines very hard.
If you're complaining about the mpg, don't lift for 37s like you wanted in the other post
Shorts
Shorts is offline
post #3 of (permalink) Old 01-20-2011, 11:04 AM Thread Starter
Newbie
bowtie4by's Avatar
winter fuel reason for poor mpg
Quote:
Originally Posted by Shorts View Post
Possible winter fuel blend. Idling and acceleration hit engines very hard.If you're complaining about the mpg, don't lift for 37s like you wanted in the other post
Thanks, Shorts! Fuel in AZ is always the winter blend (10% ethanol) due to pollution concerns, so I believe that's not the issue. Idle/accelerate is all I do anymore in Tallahassee, FL. I'll bet the cold-start conditions has something to do with it as well: more fuel injected at 40 degrees than 70 degrees ambient. I'm planning to test on the freeway: run until injectors are empty; fill with 1.0 gallon fuel; start and drive on freeway on a flat stretch at cruise-controlled 55 mpg until injectors empty again. Ya, the 37s extra weight and resistance to begin rolling should reduce the mpg even more. I will change gears to 4.88 if I run 37s.
Been on off-road.com since 2001.
G65 shocks are evil!
Boycotting Castrol for calling their Type III Syntec oil "Synthetic"; Boycotting Mobil1 for changing most of their bases to Type III and refusing to admit. Royal Purple identifies PAO/Type IV as their base; Red Line IDs Group V/ester as base. G80=Gov-Lock=>Locker,auto (not Limited-Slip)
post #4 of (permalink) Old 01-20-2011, 11:55 AM
Shorts's Avatar
I bet you're right, the cold does have a bit to do with it. The engine not getting up to operating temp will have it pouring on the fuel.
Shorts
Shorts is offline
post #5 of (permalink) Old 01-27-2011, 08:15 AM
stump runner's Avatar
Bowtie4by, you may want to do a little research before running yourself out of gas - I understand that it is not good for an electric fuel pump to run dry.
stump runner is offline
post #6 of (permalink) Old 01-30-2011, 08:08 AM Thread Starter
Newbie
bowtie4by's Avatar
Quote:
Thank you, sir, for the suggestion! I will not be running it under dry conditions for long...just a few seconds if that. The engine stumbles and coughs when fuel is almost gone. I will shut-off immediately.
post #7 of (permalink) Old 02-18-2015, 08:04 PM Thread Starter
Newbie
bowtie4by's Avatar
Re: Hi...Been a long time...checking in.
I`m simply saying "Hi!" I`ve been away for a long time. Happy to discover that I have a "Do not Delete" Post!
Human Verification
