350 TBI Problems & Questions - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Standard IFS Trucks & SUV's
Old 11-26-2007, 11:56 PM
83GMCK2500's Avatar
Journeyman
83GMCK2500 is on a distinguished road
Default 350 TBI Problems & Questions
tbi nI'm helping a guy here at school, it's an '89 K5 Blazer w/ TBI-350/700R4.
Brand new ~$2,000 350 crate engine with an rv-cam in it. Throttle body spacer (I know, they're worthless). Also has headers. New distributor (assembly), cap, and rotor. Also has 4 core radiator and electric fans.
Cam is an Elgin Pro Stock: E-923-P
Specs: Elgin Industries : Online Catalog
As far as I know the PROM/ECM is stock. What it's doing is starting and idling fine, if I ease onto the accelerator it revs fine. If I hammer it, it stumbles bad. From idle, put it into R, it stumbles and dies. From N put it into OD (or anything) stumbles and dies. If I keep the rpm up a bit it won't stumble and die. Engine also heats up rapidly.
This is the one error code:
CODE 42
Trouble Code 42 indicates that there may be a malfunction in the Electronic Spark Timing (EST) system.
During cranking, the timing is controlled by the ignition module while the ECM monitors the engine speed. When the engine speed exceeds 400 RPM, the ECM sends a BYPASS signal to the ignition module which switches the timing to ECM control. The ECM calculates what the timing should be then "tells" the ignition module via the EST circuit.
An open or ground in the EST circuit will stall the engine and set a Code 42. The engine can be re-started but it will run on ignition module timing.
The conditions for setting this code are:
* System in BYPASS mode but the ignition module is still controlling timing
- or -
* Engine speed > 600 RPM with no EST pulses (ECM controlled timing) going to the ignition module for 200 msec.
Typical causes for this code include:
1) BYPASS line is open or grounded
2) EST line is open or grounded
3) PROM or CALPACK not seated properly in the ECM
4) Poor connections between ignition module and ECM
5) Poor routing of EST harness and/or poor quality ignition wires (EMI induced electrical noise)
6) Faulty or incorrect ignition module
7) Faulty ECM
So...I'm looking for a definitive yes or no on whether or not the rv-camis fubaring the computer. If not, what else?
__________________
Devin
2007 GMC Sierra Classic 2500HD SLT, 4x4, EC/LB, LBZ/Allison, Summit White with Charcoal Leather, dealer installed Westin Platinum Series bars and a Line-X.
R.I.P. Jason (willyswanter) Payne
Old 11-30-2007, 02:46 AM
83GMCK2500's Avatar
Journeyman
Default
Hot , 44 views and zip-****-nothing for replies.
This was ordered for it:
A local parts shop with an owner who has a predilection for Chevys strongly urged the owner to get a custom PROM made up for it, so he'll do that too. We'll go from there.
__________________
Devin
Old 12-20-2007, 04:46 PM
u4ia4's Avatar
u4ia4 is an unknown quantity at this point
Default
yup, prom needs to be changed. these guys have helped me i nthe past Affordable Fuel Injection - Affordable Fuel Injection you might check with them. they seem to know their stuff. they sure know more than i do.
__________________
Have you ever taken a cooler ice fishing? Well here in Minnesota you have to....to keep your beer from freezing. ---Peacock posted this
Old 12-21-2007, 01:13 AM
83GMCK2500's Avatar
Journeyman
Default
Thanks u4ia4, the guy still needs to get a chip. That new MSD dist made a world of difference, it'll actually run down the road and shift without dying now. A chip will just finish the job.
__________________
Devin
  #5
Old 12-21-2007, 09:02 AM
u4ia4's Avatar
Default
yup, it does make a big difference in these "new fangled" vehicles. The way I figure it...if you've got to tuen a carb after every modification, then a PROM is about the same. of course the computer can handle some of the modifications, but it can only do so much.
Good luck
__________________
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
