TBI won't spray fuel. - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Standard IFS Trucks & SUV's
Old 03-08-2004, 06:29 PM
Aprentice
Joel is an unknown quantity at this point
Default TBI won\'t spray fuel.
I haven't checked anything yet, but if a 93 TBI 350 won't spray any fuel (it has spark and fuel preasure and starts up on starting fluid) is there anything other than the throttel pos. sensor and idle control sensor (and obviously the ecm and fuses) that would cause it to have NO fuel?
Old 03-08-2004, 08:33 PM
c_rock is an unknown quantity at this point
Default Re: TBI won\'t spray fuel.
Clogged injector maybe???
Old 03-08-2004, 09:34 PM
Aprentice
Niether of them spray, or even drip. I am going to start with fuses, then check the Throttle position sensor.
Old 03-08-2004, 10:24 PM
I think your fuel pump may have got bad. Have you checked it yet?
  #5
Krayzie's Avatar
Krayzie is on a distinguished road
No... TPS and IAC have nothing to do with injectors not spraying. IAC simply acts as an air bypass valve and the TPS as an injector pulse controller... basically the further the pedal goes, the more fuel the TPS lets out of the injectors... I have never heard of one stopping injector spray. You say you have good fuel pressure, what did you get for readings and where did you take your readings at? Your diaphragm in the pressure regulator/meter assembly may have failed. On a lesser note, a portion of your ignition module may have fried. Take it to the Zone and get it tested. It can shut down different sections of your fuel system or ignition. Just try it... Is it possible that you pinched the injector wires in your air cleaner or spacer? I just did that a week ago and it would not let me start my truck until I fixed the broken wire and reset the PCM.
I also had an s-10 Blazer that had broken wiring under the drivers seat that shorted out the fuel system sporadically... what a wierd problem, just driving along then all fuel just stopped. Theres lots of reasons why they may not be firing... before you go replacing injectors though, check the injector harnesses with either a noid light or a voltmeter, just to make sure there is voltage up there... I wish you luck!
  #6
Old 03-09-2004, 12:14 AM
wrath's Avatar
Carpal \'Tunnel
wrath is an unknown quantity at this point
Check to make sure the fuel pump is running. If it initially runs for a few seconds then shuts off then there are two common problems. One is an oil pressure sensor and the other is the computer isn't getting a signal from the distributor saying the motor is turning.
  #7
Old 03-09-2004, 09:09 PM
Aprentice
The oil sensor is not hooked up, but it wasn't working before either (someone had the wrong sensor in it and it always read all the way to the right), it's not hooked up now, so it still read all the way to the right at 60+. I want to hook the check engine light back up tp check for codes. What pin # is it in the ECM so I can get it working?
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
