Transmission pan bolts torque specs. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-14-2003, 02:38 PM Thread Starter
Journeyman
What torque does it call for the transmission pan bolts? I have a '98 Silverado w/5.7L engine if that matters. Thanks in advance.
murrajm5 is offline
post #2 of (permalink) Old 04-14-2003, 02:42 PM
90K5's Avatar
Re: Transmission pan bolts torque specs.
what tranny you have would probably matter more....im guessing its a 4L60e? probably about 12-16 inch lbs i think...not very tight.
90K5 is offline
post #3 of (permalink) Old 04-14-2003, 02:58 PM Thread Starter
Journeyman
I think you are right (4L60e). I tried to check them before I take it off but I don't think it would be accurate since the gasket has already been compressed and heated. They were pretty loose if you ask me. No leaking though. Thanks.
murrajm5 is offline
post #4 of (permalink) Old 04-14-2003, 04:55 PM
u4ia4's Avatar
i dont follow the specs for stuff like that. i mean [bleep]. all its doing is holding a pan on and compressinga gasket tighten it till its tighht, but not tight enough to break the bolts and you'llbe set
u4ia4 is offline
post #5 of (permalink) Old 04-14-2003, 05:12 PM
90K5's Avatar
i actually never have either, but sometimes steven torque - what i call tightening them till they all feel about the same - causes things to leak
90K5 is offline
post #6 of (permalink) Old 04-14-2003, 05:40 PM
My '89 Suburban with a TH700 calls for 13 ft/lbs,, if that helps.
c_rock is offline
post #7 of (permalink) Old 04-16-2003, 10:34 AM Thread Starter
Journeyman
That is exactly why I was asking because you can't get them all the same and that seems to cause a leak sooner or later. Compressing the gasket too much will also. I don't want to go through the hassle of spilling fluid everywhere just to replace the gasket from where it leaked due to incorrect torque on the pan bolts.
murrajm5 is offline
post #8 of (permalink) Old 04-16-2003, 10:36 AM Thread Starter
Journeyman
That might be too old of a vehicle to go by because my torque wrench only goes down to 10ft./lbs and that was WAY too much. I believe it is suppose to be something in inch/lbs.
murrajm5 is offline
post #9 of (permalink) Old 04-16-2003, 01:34 PM
Ahhh....does wrist tight tell you anything? You don't have to get western at all with it. The object is to get the thin little sheetmetal pan to evenly touch the gasket and seal snugly.
Human Verification
