TH350 Rebuild Time - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Standard IFS Trucks & SUV's
Old 05-30-2000, 11:41 AM
Default TH350 Rebuild Time
My Th350 has finally given out. I am now trying to decide whether or not to rebuild it or replace it with an aftermarket one. I have looked at the t-700 from jet performance (i.e. Premier Performance) and the sm-465. Has anyone had a similar decision to make and if so what did you go with? Price is a factor, the mechanic I took it to says it will be around $1000 to rebuild it. If I stick with the 350 is there a cheaper way to go about it?
Old 05-30-2000, 12:39 PM
Default Re: TH350 Rebuild Time
You better get another mechanic. I just got a damn nice rebuild (new clutched, plates, seals, gaskets, torque converter and valve body) for $275. I pulled the transmision myself. Been running it for 6 weeks now. That sounds very high.
Old 05-30-2000, 01:06 PM
Pooh-Bah
Scoobydoo is an unknown quantity at this point
The turbo 350 is the cheapest tranny to rebuild!!! that price is WAY TOO HIGH !!!
It shouldn't cost more than around $250. I would stick with the T350, but find a different shop. Also since you are doing the tranny now, I would suggest you get a heavy duty torque converter($100), and while they are rebuilding it, now would be the best time to put a shift kit in it($60), and a cast aluminum pan with a drain plug, cooling fins, 2 qts more fluid($100). And if your truck does not already have one? put the biggest tranny cooler on that will fit($60). If you do this stuff you still should be well under $1000 even if you have the shop R&R it for you. But with these modifications, this should be the last tranny you will ever need. (heat kills trannys)
Old 05-30-2000, 01:55 PM
FWP
I agree with Scooby, with a couple additions. A good shop will know what I'm refering to. Have the direct clutch drum bushing replaced with the wider one, stock is .500, replaced with a .750 wide bushing. Also add a hardened intermediate roller clutch outer race, the stock ones tend to crack. I like to run a tranny temp gage, you can make sure you're not smoking anything. If you're interested in the details, Summit sells an excellent manual "Turbo hydra-matic 350 handbook.
Maverick [img]/wwwthreads_images/icons/smile.gif[/img]
  #5
Old 05-31-2000, 12:45 PM
His price is in line. The stator shaft splines strip off on high miler trannys and if they replaced that then it sounds reasonable. I rebuilt mine myself and after getting it appart I found the the stator shaft about stripped and the foward sprag had detonated and chewed up the forward drive drum. Local shop sold me some used parts that were in near new condition for $70 including a complete pump with good stator shaft he beefed up a sprag for me (you double the springs real simple but effective trick) and a complete 250 foward drum that by swaping the piston out of the TH350 works fine and you can get the extra clutches in that the 350 uses over a 250. So to do it myself with the extra destruction from the blown sprag it cost me right at $200.
parts list
rebuilt converter
new clutches
new steels
new seals/ gaskets
sprag that was beefed
foward drive drum
pump
tranny cooler line flush
Wide stator shaft/converter bushing
book on how to
Grim-Reaper
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
