| GM Small Trucks & SUV's All discussion of S-Class Trucks and SUV's |
10-10-2000, 06:49 PM
OBD2 P0153 O2 Sensor - Where?
Hello All,
My '96 Blazer has the trouble code of P0153 - "O2 Sensor Circuit Slow Response (Bank 2 - Sensor 1)". It supposedly (Haynes) is after the Cat. I was wondering if anybody has some more information on this. Haynes Manual lists some ways to check it. Is this something I should immediately replace?
TIA, Roy |
10-15-2000, 04:40 PM
| Enthusiast | | Join Date: Jun 2000 Location: TN
Re: OBD2 P0153 O2 Sensor - Where?
It sounds like the heater went out in the sensor causing it not to heat up quick enough and setting a code. I would have the code cleared, and if it comes back immediately, change the sensor. Saw this a lot at the dealer. Hope this is helpful.
David G.
'91 S15 Jimmy 5.7L 4X4
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
