Borg Warner T-5 tranny: what fluid? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Small Trucks & SUV's
Old 09-12-2000, 09:40 AM
The_Sandman_454's Avatar
The_Sandman_454 is an unknown quantity at this point
Default Borg Warner T-5 tranny: what fluid?
I was wondering what fluid you use in your Borg Warner T5 transmission... I've heard everything from gear lube to auto tranny fluid... It's about time for me to change mine, and I figured it'd be about time to ask... [img]/wwwthreads_images/icons/crazy.gif[/img]
Tim
ORC Land Use columnist
My August article on ORC
http://www.off-road.com/land
Old 09-12-2000, 11:58 AM
Default Re: Borg Warner T-5 tranny: what fluid?
The book says to use ATF, But many people have told me to add a quart of sae30 motor oil to it. I think it just thickens it up a bit. I tried it when I had the tranny out last but did'nt really seem to notice a difference at all. All the times before I have always run all ATF.
Good Luck
Nick
allterrain_87@hotmail.com
83' s10 extended cab 4x4 supercharged 2.8l v6
Old 09-12-2000, 06:49 PM
Use ATF.
Old 09-12-2000, 06:55 PM
Alrighty, that was what I was thinking, but wanted to be sure since I saw someone on the SWB Jeep board here talking about using gear lube in their T5 and having it work good... [img]/wwwthreads_images/icons/cool.gif[/img] Thanks guys...
Tim
  #5
Old 09-16-2000, 10:36 PM
The tolerances are pretty close and gear lube would cause alot of excess heat.
If you run motor oil in a WC T-5 the EP additive will distroy the carbon syncros
I run 15w-50 synthetic but mine was redone with bronze syncros.
The factory does reccomend ATF, Mobile does make a synthetic ATF if you
wanted to go that route.
HAWG WILD
<font color=purple> ALL THOSE WHO WANDER ARE NOT NECESSARLY LOST </font color=purple> [img]/wwwthreads_images/icons/crazy.gif[/img]
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
