99 S10 won't start - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Small Trucks & SUV's
Old 05-16-2013, 01:49 PM
A1980GMC's Avatar
A1980GMC is an unknown quantity at this point
Default 99 S10 won't start
My brother in law's 1999 4 banger S10 won't start. First thought it was the starter. He now has a new starter and new battery. When you try to crank it, it turns over but very very slowly. Like I said the starter is new and the bettery is new. I don't think the problem is it not wanting to start it just isn't turning over like it should or with enough juice. Last night we removed all of the spark plugs to see if it would turn over any better. It barely turned over any better.
Can their be a problem with getting enough juice down to the starter? We tried late last night to hook up a remote starter switch. Bypass the ignition by putting a direct hotwire to the S terminal on the starter. Got nothing, but then a rain storm came in and we had to head inside.
I am running out of things to try. Any suggestions?
__________________
2002 7.3L Excursion!!!!
Old 08-29-2013, 06:27 PM
Newbie
edsmagichands is on a distinguished road
Default
don't know if you still need help but if you do, first put a wrench on the crank bolt and turning it by hand. if it turns freely its electrical problem. if not, he probably overheated it causing pistons/rings to expand, or ran it out of oil causing bearings to seize, either way its toast. oh, make sure its not in gear when you try this. if all good, dont forget battery cables. they must be clean,tight ,corrosion free inside and outside. visual inspect not good enough test with meter or put new on if not sure.
PS: new stands for NEVER EVER WORKED trust nothing specialy aftermarket reman
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
