2001 chevy tracker 4x4 not working - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Small Trucks & SUV's
Old 12-15-2011, 04:27 PM
Newbie
jessicamoores@gmail.com is on a distinguished road
Default 2001 chevy tracker 4x4 not working
When 4x4 is on the axles turn with the wheels so the hubs are good,the front driveshaft is locked so the transfer case is most likely good,i was told there was a pump that built up pressure to lock up the axles in the differential,does anybody know where it is and how to test it,or any suggestions on something else that might be wrong,any help would be awsome,Thanks
Old 12-15-2011, 10:21 PM
stump runner's Avatar
stump runner is on a distinguished road
Default
I'm sorry, I don't quite follow your trouble shooting you've done. I believe the easiest way to narrow down where the trouble lies is as follows:
1) engage 4wd
2) set the parking brake and jack up 1 front wheel
3) attempt to rotate that wheel
If all is well with the world you will not be able to spin it. If you can, the trouble lies just past the last rotating part. (IE: if the driveshaft spins, the problem is in the transfer case. if the axle shaft is the last rotating part, it may be your front diff or central axle disconnect, if so equipped)
Old 12-15-2011, 10:59 PM
Newbie
Default
ya thats what i did i guess i wasnt specific enough,my bad,4x4 engaged,jacked up front end,both wheels spin with axles and then i checked the drive shaft and it was locked,my 4x4 indicator light comes on, after a little research i learned that the 4x4 indicator light on my dash will only come on if the pump unit builds enough pressure,so i figure i either have a air leak big enough to stop the axles from locking up or the unit in the differential that locks the axles is faulty,(that would suck)im gonna check for leaks in the morning and go from there,thanks
Old 12-24-2011, 12:33 PM
Default
so, is the problem that the light does not come on, or that the wheels do not turn in 4WD?
maybe this thread will be helpful:
2000 chevy tracker front axle question
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
