H1 engine swap question? - Page 2 - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Chevy and GM > GM Hummer, Humvee and Hummer II
GM Hummer, Humvee and Hummer II Discussion of all things relating to the General Motors Hummer, Hummer II and Humvee
  #11
Old 06-03-2004, 12:20 AM
desertrat67's Avatar
desertrat67 is an unknown quantity at this point
Default Re: H1 engine swap question?
Give gale banks a call and see if they have a turbo for the NA 6.5 the will fit in an H1. If not, i would try and find a 6.5 TD from a wrecked H1 and swap that in. As for the Duramax option, i think that engine is just too darn big to fit in the tight confines of the H1's engine bay.
  #12
Old 06-03-2004, 10:10 AM
http://www.turbodieselregister.com/f...p;pagenumber=1
Oh for pity's sake. Just put a 24V Cummins in with P7100 mechanical pump.
Hey desertrat67, how much bigger is a 6.6TD than a Vortec 8100, because I've seen a 496 in an H1. [img]images/graemlins/shocked.gif[/img] [img]images/graemlins/grin.gif[/img]
  #13
Old 06-10-2004, 09:17 AM
it is a few inches wider and taller. I don't know the numbers, but i know it takes quite a bit of fanagaling to get a big block chevy gasser into one of those. To give a little perspective, a 496 comes from the factory in the 3/4 ton acalanche, but a new frame section and a 2 inch body lift are required to fit one in the same truck. The front portion on the frames of the HD pickups is different depending on whether you have a Duramax or a gasser.
  #14
Old 06-10-2004, 09:44 AM
Wow, I'll have to take a look at the service trucks at work then. One is an '03 2500HD w/496, the other is an '04 3500-SRW w/Duramax. I had no idea that the frames varied in size between those two engines, I would've guessed that the frame cradling a diesel was beefier, but that was it. That's crazy.
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
