GenRight Off-Road has fuel tank/cell options! - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Supporting Vendors > GenRight Off Road
GenRight Off Road GenRight Off Road
Old 09-07-2013, 05:56 PM
Apprentice
GenRightTom is on a distinguished road
Default GenRight Off-Road has fuel tank/cell options!
GenRight single gas tank option:
SKU GST8002-2
Building your JK into the ultimate rock crawler? Then we have the tank so you can put a 4-Link rear suspension in you Jeep JK.
This is the GenRight Crawler™ Gas Tank to fit a Jeep JK (2007 - Current). It is specifically designed to REMOVE the factory tank from under the middle of the vehicle so you can run true Rock Crawling triangulated 4 link rear suspension (yes, no trac bar!).
This tank follows in a line of innovative and trail proven, top quality gas tanks produced by GenRight.
The tank assembly is relocated to the rear muffler area and mounts in a way that still works with your factory gas filler. It even re-uses your factory fuel pump module so can work with all your factory emissions equipment so you won't get any check engine light or have computer issues.
FEATURES:
Hangs no lower than the factory muffler did (does not hurt departure angle).
20 gallon fuel capacity.
Creates room for triangulated 4 link suspension systems.
Mounting location keeps center of gravity low.
Re-uses the stock Jeep fuel pump module.
1/8" thick Aluminum alloy tank is TIG welded.
Foam liner between tank & skid plate.
Includes a 3/16" thick heavy duty steel skid plate.
Stainless steel hold down strap.
Drain plug.
All tanks are 100% pressure tested.
Patent Pending.
INCLUDES:
Fully assembled fuel tank in a Heavy Duty skid plate.
New factory Mopar roll over / vent valves.
New tubing to adapt tank to new mounting location.
New cargo area floor cover (BKT-8100)
Additional NOTES:
Because of shape and location changes, installation of this product requires changes to the exhaust.
Requires removal of the rear floor tool storage area (the jack remains in the very rear compartment).
To install this product it does NOT require a body lift.
If a rear sway bar is desired, installing this tank will requires switching to a Currie "AntiRock" type rear sway bars. Because the stock sway bar must be removed.
Can be used with factory tow hitch.
__________________________________________________ _____
GenRight's Extended Range Gas Tank:
SKU GST8202-2
Never hassle with transporting and transferring gas from gas cans again with the GenRight JK Extended Range additional tank!
The GenRight Extended Range Tank will give you a 600 mile range! The 20 gallon extra tank increases your total capacity in a 4 door JK to 45 gallons!
The nice part is you will not notice the extra gas tank since it is mounted under the body in the very rear of the vehicle and fills through the stock gas cap.
It was specifically designed to be mounted under the rear cargo area of a Jeep JK so you can keep the center of gravity low!
This tank follows in a line of innovative and trail proven heavy duty gas tanks produced by GenRight.
The tank is not a "transfer tank" it is a completely redundant tank with it's own fuel pump that is switched by you from the dash. Both tanks tie back into the factory fuel and emissions equipment so you won't get any check engine light or have computer issues.
FEATURES:
Additional 20 gallon fuel capacity.
Accepts the stock Jeep fuel pump module.
Drain plug.
Fits in both the 2 and 4 door JK models (2007 to Current).
Patent Pending.
INCLUDES:
New cargo area floor cover (BKT-8100).
Dual tank wiring harness (GST-8100).
Additional NOTES:
Requires the purchase of another factory Jeep fuel pump module (from Jeep dealer).
Because of the mounting location, installation of this product requires changes to the exhaust.
Requires removal of the rear floor tool storage area (behind rear seat).
Requires removal of the stock sway bar, but will work with Currie "AntiRock" rear sway bars. Sold Separately.
Aftermarket Lifts, that use a different trac bar may be an issue, as the tank was designed to fit with the stock rear trac bar.
Driving range quoted above is calculated on 40 gallons at 15 miles/gallon.
Old 09-07-2013, 05:57 PM
Apprentice
Default
20 gallon Fuel Cell:
SKU BST2100-1
GenRight has done it again! This is the fuel tank everyone has been waiting for!
Finally a tank specifically designed for hard core Jeeps that are no longer driven on the highway. By using this model tank it opens the entire under body area for radical rear axle relocation. It is intended to be mounted behind the driver and passenger seats in the cargo area of a Jeep to keep the weight of the fuel central in the vehicle. Fits the new JK fuel module too!
FEATURES:
Re-uses the factory Jeep in tank fuel pump module and sending unit.
Includes the factory vent valves (aka roll over valves).
Tank is made of 1/8" thick Aluminum alloy and TIG welded.
Includes two stainless steel mounting straps for secure mounting.
Tank capacity is 20 Gallons.
Size is 30" long x 12" tall x 14" wide.
Includes special baffles inside tank that can accept Fuel Cell safety foam.
Includes a metal quarter turn, non vented (sealed) gas cap.
2 Models that are designed to work with factory Jeep fuel pump modules from '97-'12.
Includes protective metal cover as shown in the pictures.
NOTES:
Due to the non-stock location of this tank, this tank is not considered street legal.
For maximum safety and occupant protection we highly recommend using our metal protective cover be used to protect the tank and fuel pump from getting damaged while the vehicle is in operation!
Fuel Cell safety foam is an optional upgrade.
The aftermarket sending unit is required when using Fuel Cell safety foam (an optional upgrade).
Electrical, fuel and vent connections must be extended to reach the new location.
Race Legal 20-Gallon Fuel Cell:
SKU BST2500
This is the Race Legal fuel cell for the Stock and Stock Mod classes at KOH!
Finally a fuel tank specifically designed and manufactured with a genuine rubber bladder to be competition legal fuel cell for the Ultra4: Stock 4600, Mod 4500 and 4400 class vehicles!
By using this style tank it opens the entire under body area for radical rear axle relocation. It is intended to be mounted behind the driver and passenger seats in the cargo area of a Jeep to keep the weight of the fuel central in the vehicle. Fits the new higher pressure & volume JK fuel pump module too!
FEATURES:
This cell re-uses the factory Jeep in-tank fuel pump module and sending unit.
Includes a factory vent valve (aka roll over valve).
Tank enclosure is made of 1/8" thick Aluminum alloy and TIG welded.
Rubber fuel cell bladder capacity is 20 Gallons.
Tank can also accept Fuel Cell safety foam.
4 Models that are designed to work with factory Jeep fuel pump modules from 1987 to 2013.
NOTES:
Depending on the year of your factory pump module you may need to modify the pump unit tio reach the bottom.
Fuel Cell safety foam is an optional upgrade, and technically required by the Ultra4 rules.
If you intent to remove the gas cap and "quick fill" the tank remotely, the vent line must be enlarged to at least 3/4" diameter.
As per the rules, a vent line (with roll over valve) will need to be installed in the pump module mounting plate.
Quick reply to this message
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
