OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Ford Forums > Ford General Discussion and FAQ
Ford General Discussion and FAQ Ford, general discussion forum and Frequently Asked Questions.
Old 02-11-2007, 11:45 PM
Aprentice
Hummerkiller is an unknown quantity at this point
Default From M151 to M151-LC the Axels!
To get the proper performance required to make the 1962 M151-LC a real desert Racer, certain new editions had to be used and modified.
Here are the two axles Dana 35 and Dana 30 that will be mounted under the uni-body.
Do to the wimpyness of the Dana axels in stock form we will be pulling the guts and milling all new internal parts in our shop as soon as we complete the axel case redesign for centering.
The newesr stronger gears and shafts will then be reinstalled into the axel case housing.
The axles housing body will need to be modified so that both the pumpkins are centered, not slightly off center.
This is do to the uni-body design, the M151 tranny was centered, the Jeep Wrangler type axels are off center, so to make the tranny work everything has to be centered as well as balaced down to the use of a Mic in our case.
So we will have to cut the front axel shell and internal parts and mill and reweld them to work from the m151 uni-body design.
On a Jeep Wrangler the rear axel is already centered so it will not have to be modified just rebuilt with stronger precision parts.
Thank Goodness as the cost to do these projects can get steep if we have to send something out to a shop!
This simple mod also gives us more play with a suspension lift as well.
We shall cut the leaf plate mounts off the bottom of the axels and reweld them on the top giving us about 4 additional inches of suspension lift.
We must work out the weight difference between the front of the mutt and the rear, placing some ballast along the unibody and the rear of the vehicle to balance eveything out, this gives us better jump radius.
The weld lift support and the anchor braces shall do the rest, keeping vibration to a minimal, and allowing us smoother landings during air jumps.
Here are a few pictures
The too rough axels that have not been painted yet are the Dana front and rear axels, the third axels is our spare axels which we are finished painting and will be built this week.
Here are some of the new parts for the spare axel.
Here are a set of the rear fender A2 lifting/tow loops sanded primed and painted and ready to be installed.
Nate got these ready last night.
Old 02-19-2007, 08:03 PM
xjy173's Avatar
Carpal \'Tunnel
xjy173 is an unknown quantity at this point
Default Re: From M151 to M151-LC the Axels!
I was wondering if the Dana axles were out of the Cherokee you mentioned in another post; if so the Dana 30 front might have the vacuum disconnect.
Search this Thread:
Advanced Search
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
