There aren't any lifts for your Mazda. I've seen this question on many forums and actually a few seperate continents, and no, there aren't any. Basically you can crank your torsion bars a little, do something with the rear leaf springs, hack your fenders, and/or make a body lift to get bigger tires under it. Other than that swap a solid axle under the front with leaf springs or a custom coil setup is your other option.
Sway-A-Way does have some uprated torsion bars, so you could crank your A-arms up a little bit without getting a shitty ride and no suspension movement.
www.SwayAWay.com We put a set in my buddy's 92 Toyota. $99 and they worked great. Excellent torsion bars.[img]images/graemlins/cool.gif[/img]
For the record, Ford doesn't own Mazda, they have a % of the company's stock. I forget if it's a controlling majority though, like GM has in Isuzu.[img]images/graemlins/smile.gif[/img]
