dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | General 4X4 This is the place for four wheelers and off roaders to come together as one big happy family. With over 20800 registered members, everybody has to have something in common. |
02-16-2003, 05:29 PM
| | | Bolt-On-Recovery Shackle? Does anyone know were I can get the Griffin Recovery (or something like it) Bolt on shackle. They seam to be out of business. This is a bolt on recovery shackle that you can install on any flat surface. . . There was an article on the off-road.com site under
off-road/jeep/reviews/griffinrecovery/ . thanks |
02-17-2003, 11:28 AM
| | | Re: Bolt-On-Recovery Shackle? http://www.expeditionexchange.com/smb/index.htm
Or make your own for pennies using two pieces of scrap 3/8" angle iron butted together and drilled out with a 3/4" hole for the shackle. Depending on how heavy your recovery needs are, you could always use thicker angle iron. |
02-18-2003, 02:37 AM
| | | Re: Bolt-On-Recovery Shackle? Here is a site that has them. I am thinking about ordering a set for my truck, so if you get them from this place let me know how they look! [img]images/graemlins/laugh.gif[/img] http://www.r-p4wd.com/java/products.htm
[img]images/graemlins/scs.gif[/img] |
02-19-2003, 02:15 AM
|  | Keyboard Implanted | | | Join Date: Oct 1999 Location: woooooo pig sooooooie!
| | Re: Bolt-On-Recovery Shackle? i'm sure they are underrated, but i wouldnt trust something with a 3ton rating. that's like sailboat line stuff [img]images/graemlins/grin.gif[/img] as birddog suggests, build your own or buy the $10 weld-on ones at northern tool that are rated to 46k lbs. if you welded them to 1/2" plate and drilled 4 holes in the plate, they would bolt on to anything as you requested [img]images/graemlins/smirk.gif[/img] |
02-20-2003, 03:13 AM
| | | Re: Bolt-On-Recovery Shackle? The 3/4 shackles that I have are only rated for 6400 lbs. I think thats why the manufactures only rate them for 3 tons. Its still a little under, but I would guess that the manufacturer is only covering his butt from getting sued. I wouldnt mind having a set and for $30 that doesnt sound to bad to me. Hey Muddy do you know of a 3/4 shackle that are rated any higher, maybe Warn used the lower weight ones? |
02-21-2003, 12:50 AM
| | Re: Bolt-On-Recovery Shackle? I dont know, but any shackle you find for overhead lifting that's rated at 3 tons is going to be good for 10 tons or so... there are huge safety margins in overhead lifting, for obvious reasons. You can assume that the Warn 3 ton shackle is good for at least 6 tons breaking strength, probably more. They will throw in a huge safety factor for the reason you state, liability. I used to have one of those Warn 3/4" shackles (lost it in a swamp) and it was the last thing I would've worried about in an extraction, especially if the pin is loaded to one side where it meets the "wishbone", which it always seemed to do. Search eBay under "Business & Industrial", there's no telling how big you can get those shackles if you're worried. |
02-21-2003, 11:12 AM
|  | Old Hand | | | Join Date: Jan 2002 Location: Alberta, Canada
| | Re: Bolt-On-Recovery Shackle? How's this for a shackle: |
02-21-2003, 01:03 PM
| | Re: Bolt-On-Recovery Shackle? I really hope that's digitally enhanced [img]images/graemlins/blush.gif[/img] [img]images/graemlins/grin.gif[/img] |
02-22-2003, 03:56 AM
| | | Re: Bolt-On-Recovery Shackle? Not really worried about it. Just curios if there were any higher weight but still in the 3/4 size. But then again the higher weight rating of the shackle justs means I would break the next componant in line. Deffinatly dont need that big thing Mark posted a picture of!!! Wonder what kind of battleship that came off of?!!!
02-22-2003, 09:26 AM
| | Old Hand | | | Join Date: Dec 2002 Location: Louisiana
| | Re: Bolt-On-Recovery Shackle? Maybe he's got "little man syndrome" | | Thread Tools | Search this Thread | | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Off-road forums – a community of enthusiasts discussing general off road issues from ATVs and UTVs to racing, jeeps, trucks and other 4x4 vehicles. Join the off-roading nation and share your knowledge or just cool info about your ride. All times are GMT -5. The time now is 09:38 PM. |
