dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | General 4X4 and Off-Road Ask questions or share info that applies across makes or models, things of general off-road interest. *Make-specific, please look below for appropriate forum.. |
11-01-2009, 07:27 PM
| | Newbie | | Join Date: Oct 2009 Location: virgina
| | Glowing exhaust !help!
Hows it going,I'm new to the site  I've got a 95 xj with a glowing manifold, can any one help. I've tried everything,I want to drive it again really bad |
11-04-2009, 12:53 AM
|  | Journeyman | | Join Date: Dec 2007 Location: Battle Ground Washington
what modifications does the xj have at this point? lift, oversize tires?
we used to have a work van that was geared too low. at 65 mph the 440 v8 would spin over 4500 rpm. the muffler looked like a third brake light underneath. think it was running lean also but ? the manifold (glowing bright orange) melted a hole in the dog house (engine cover inside cab). was realy hot on passenger's leg. by the way- cardboard does not make a good insulator when it catches fire inside the cab!
11-06-2009, 04:27 PM
| | Specs.
i'M BORED OVER .30, MADE MY OWN INDUCTION "SOUNDS LIKE A WIND TUNNEL" ,POWER AID SPACER, 8.5 MSD WIRES, MSD COIL, HOLLOW CAT, 6 INCH LIFT, 33'S, "TECHS OUT FINE GOING DOWN THE HIGHWAY" AND RUNNING TRIPLE PLATINUM PLUGS . wORKING ON PRESSURE TESTING EACH CYLINDER AND CANT GET PRESSURE TO HOLD. I HAVE YET TO FIND WHERE ITS GOING. THANX |
11-07-2009, 03:33 PM
Kinda grasping at straws here. is your O2 sensor after the cat? If by hollow you mean no catalyst it's possible that your O2 sensor is causing the engine to run lean or something like that. hopfully somebody with more expertice will chime in.
11-09-2009, 05:31 PM
| | Glowing
O2 SENSOR IS IN THE DOWN PIPE RIGHT AFTER THE MANIFOLD. I HAD IT IN THE SHOP AND MECH. SAID THAT "EVERYTHING" IS WORKING RIGHT,SENSOR(S) THAT IS, o2 SENSOR IS OPENING AND CLOSING THE WAY IT SHOULD. I HAVENT FOUND YET ,BUT IM WONDERING IF THE AUTO PARTS STORE GAVE ME A CAM FOR A 4.2 INSTEAD OF 4.0, DONT REALLY KNOW IF THEIR INTERCHANGABLE, OR MAYBE THE CAM I HAVE IS BADLY MACHINED.  GETTING CLOSER TO A SMALL BLOCK 350 EVERYDAY |
11-09-2009, 07:59 PM
| | Novice | | Join Date: Oct 2009 Location: Canada
| | Re exhaust glowing
If you tried to do a compression test & it won't hold pressure and your exhaust manifolds glow. Sounds like you burn't your exhaust valves which allow exhaust to pass due to the fact the valve won't seal in its seat. This would cause glowing. |
11-10-2009, 11:25 PM
| | Glowing
I just finished air testing each cylinder w/ the manifolds off and sure enough every exhaust valve is leaking  ! im still a little concerned, air sounds like it is leaking into the block  . the rings have got to be right because the air pressure is pushing the pistons down if their at the top. Ill just have the mach. shop grind the head down or resurface. milling it down should be better performance any how, giving a better comp. ratio  Ill let you guys know what comes of this. later
Today, 12:32 PM
| | Re exhaust glowing
Must of looked pretty cool at night glowing. | | Thread Tools | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 10:48 PM. |
