ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > General Off-Road > General 4X4 and Off-Road
General 4X4 and Off-Road Ask questions or share info that applies across makes or models, things of general off-road interest. *Make-specific, please look below for appropriate forum..
Old 07-25-2009, 08:25 PM
Newbie
deadweight is on a distinguished road
Default Gear ratio question. please help 37s on F150
Hey guys I am running 37 on my 04 F-150. I need to know what gear ratio is best to run with this set up. I drive the truck everyday and it dosent see very much off road, I jus think that it could do better. Also what impact will new gears have on my crapy fuel mileage? Thanks for any help.
Old 07-29-2009, 05:02 PM
c_rock is an unknown quantity at this point
Default
I've seen calculators somewhere but cannot seem to find them now. I would suggest 4.56 or something close to that. I put 4.10 in my Suburban with 35" tires, and it just isn't quite enough for my likings. I'm thinking that your truck is lighter than my Sub, and is turning a little bigger tires, so 4.56 should be about perfect.
You should post up in the Ford section to see if someone there can give you more specific advice.
Old 10-02-2009, 04:00 PM
Novice
GerryK61 is on a distinguished road
Default Re gear ratio
If your running a 5 speed manual trans Or a Auto with overdrive I would go 4.88.
Old 10-09-2009, 11:06 AM
Newbie
riverrat is on a distinguished road
Talking Gear Table
I had the same question and put in the Ford Section, I ended up finding this table that help me better determine what was needed. Link provided below.
4Lo.com :: Gear Ratio & Tire Size Chart
~RR
  #5
Old 10-20-2009, 09:00 PM
Dale813's Avatar
Newbie
Dale813 is on a distinguished road
Default
Dont know what you should run but I have 37" Swamper boggers on my 1986 Toyo 4x4 pickup with a 4 banger and I have 488's. I should have 529's.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
