Broken Frame Rail- Any ideas what to do? - Off-Road Forums & Discussion Groups
General 4X4 and Off-Road Ask questions or share info that applies across makes or models, things of general off-road interest. *Make-specific, please look below for appropriate forum..
post #1 of (permalink) Old 03-02-2003, 11:57 PM
Mechanix
Ok this isn't really a huge problem but I want to know what I could do about this. I have an 88' Bronco II and the left front frame rail has about 4-5 inches gone off the end. It looks like whoever had it before me probably bent it and took a torch and cut it off. Then they did the samething to a boneyard frame and bolted the two pieces with a plate and 4 bolts. Could I get this piece reinforced and welded up good or do I need to replace the frame. If I turn it into a trail vehicle I will probably put a winch up front so it would have to be strong. Any thoughts/suggestions welcome.
Also wondering about cutting the top off but I'll post that in the vehicle forum first. [img]images/graemlins/crazy.gif[/img]
post #2 of (permalink) Old 03-03-2003, 03:14 AM
Fluke
Re: Broken Frame Rail- Any ideas what to do?
If everthing is straight I would unbolt the peice of frame and clean them up to bare metal put it all back together and weld it up. That is if you have access to a welder and its big enough to do the job. If your still worried about it you can weld peices on the top and bottem of the "C" to make it even stronger. And if you have enough room you could even box the frame in. The most important thing with any frame fix is to not get the frame too hot, but hot enough to get good penatration. You said it looks like they used a torch to remove the peice of frame, thats not the best way to cut a frame you want to reuse, when you heat them up you take the strength out of them. I think youll be ok, if it were mine I would try it and see how it turns out. Changing a frame is a pain in the arse!!! If your going to put a winch on while you have the welder out I would weld a support between the front of the frame rails to help keep it from buckling or get a front mount receiver. I did this on my truck just as a precaution. Just my two cents!!!
[img]images/graemlins/scs.gif[/img]
post #3 of (permalink) Old 03-03-2003, 07:18 PM
krabysniper's Avatar
Yes you can weld it up and I agree I would box it for strength if you intend to put a winch on it, otherwise don't sweat it. It is only the front four or five inches.
krabysniper is offline
post #4 of (permalink) Old 03-05-2003, 11:42 AM
Hello there Mechanix.... it was mentioned that
"If everything is straight I would unbolt the peice of frame and clean them up to bare metal put it all back together and weld it up. That is if you have access to a welder and its big enough to do the job."
Correct...
" If your still worried about it you can weld pieces on the top and bottom of the "C" to make it even stronger. "
The best way is to reinforce the frame rail is from the inside with a piece of box tubing or channel tubing drilled and pinned ~ 3/8" or so to align and then weld along the outer edges of the inside reinforcement box. This helps in the overall strength and helps to prevent overheating of the orig frame rail. I would think that 2 pins at either end drilled and filled (welded) should do it.
"And if you have enough room you could even box the frame in. The most important thing with any frame fix is to not get the frame too hot, but hot enough to get good penetration. "
See above
"You said it looks like they used a torch to remove the piece of frame, that's not the best way to cut a frame you want to re-use, when you heat them up you take the strength out of them."
Consider recutting the frame in a spot 1-2" back from the orig torch cut... use a cut-off tool. Much cooler temps and cleaner cut.
Hope this helps...
billybob is offline
post #5 of (permalink) Old 03-11-2003, 02:24 PM
I would also box it like Krabysniper said if you intend to use it as a recovery point.
Human Verification
