Converting to 4wd Ranger???? - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Ford > Ford Ranger, Bronco II, Explorer
Ford Ranger, Bronco II, Explorer Discussion of all Ford mini and mid-sized 4x4 vehicles to include the Ranger pickup, Bronco II and Explorer SUV's.
Old 03-31-2005, 11:01 AM
-=Azo=- is an unknown quantity at this point
Default Converting to 4wd Ranger????
what do you need to convert a 2wd 1987 ranger to 4wd? driveshaft transfercase axle? send me a write up or somthing on it too thanks
Old 04-01-2005, 11:05 AM
tanbuddy is an unknown quantity at this point
Default Re: Converting to 4wd Ranger????
You might need a 4x4 transmission and crosmember too, the 2.5" factory rear blocks adnd shocks, both drive shafts, cut hole in the floor. For the fron get the 4x4 springs and shocks as well.
I dont know if the pitman arms are the same or not. More involved than u think, good luck
Old 05-30-2005, 07:53 AM
rinconlucky
Azo
I have everything you need. 88 bronco ll body rough, interior rough, engine good, 5 speed transmission good, transfer case good, both axles good. starter drags but this truck can be started and driven. 500 dollars takes all. clean title.
Old 01-06-2010, 09:26 PM
Newbie
dock83 is on a distinguished road
Default ben there doen that
Good luck too you you need the crossmember out of a 4x4 the one that goes under the engine a front end and rear end too match gearing. drive shafts front and read the coil spring brackets off of a 4x4 trannie and transfer case manual shift easier no amount of wiring, rear spring blocks but I think the front coil springs are the same from a 2 wheel too a 4 wheel.l Yes you also need a pittman arm off of a 4x4 and the steering linkage. And before I forget lots and lots of nervesssssssssssss. This build took me 2 full weeks too finish and I ended up finishing up with a short wheel base 198 whatever ford ranger. Cheeper too buy another truck this is a really big task. My hat goes too you.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
