351 Rear Main Seal Leak - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Ford > Ford Lounge
Ford Lounge General discussions and Frequently Asked Questions.
Old 07-31-2003, 11:50 PM
Default 351 Rear Main Seal Leak
I just got a 78 Bronco for 300 bucks, but after I got it home I found out that the rear Main Seal is leaking...my question is: Can you change these seals "WITHOUT" pulling the engine out?? Also the dip stick tube is drenched????
Old 08-01-2003, 12:41 AM
havack's Avatar
Pooh-Bah
havack is an unknown quantity at this point
Default Re: 351 Rear Main Seal Leak
you could pull back the tranny....
Old 08-01-2003, 08:52 AM
MY2ND78 is an unknown quantity at this point
Yes, there is enough room in a 78/79 to drop the pan without pulling the engine or tranny. It's a two piece seal so you'll have to drop the #5 main bearing cap. Good time to check bearing wear. If the dipstick tube is soaked with oil, but the rest of the engine isn't, you might have high crankcase pressure (bad rings). Check your PCV valve first, then pull the valve covers and check for a sludgy waxy buildup that might be clogging the oil return holes.
Old 08-01-2003, 11:50 AM
Thanks for that info. I'm glad to know that I DON'T have to "pull back the tranny"!!!! LOL
  #5
Old 08-01-2003, 05:58 PM
BigNorm's Avatar
BigNorm is an unknown quantity at this point
Just be glad you have a 78, After having a solid front axle the next cool thing on the list is that you can actually drop the pan unlike any of us with 80 on up. I'm glad you can do this without having to pull the motor. Good luck! [img]images/graemlins/smile.gif[/img]
  #6
Old 08-02-2003, 01:26 PM
Thanks for the reply all!! I think All in All I got a fair deal for $300.00 and am VERY glad to find out it's a two piece rear main seal. This will give me a chance to replace the Oil Pan and pump while I'm at it!!!!! It's a stock '78 Custom with 165,000 miles in fairly good shape with a very strong 351M and C-6 Trans, (wish I had a 4 speed)!!! If nothing else it's a good parts truck!!!!
  #7
Old 08-05-2003, 09:39 PM
yea man really easy rear main to change.
i did it not 3 months ago. drop the pan, and watch the dipstick.. i couldnt get mine out at the pan.. so the tube and pan came out as one... um what was next? yea the number 5 journal i think its name is.. remove it. use a small screw.. thred it into the end of the old seal and pull/slide it out. gently.
then reinsert the new one.. more gently, not with a screw of course.. RTV the journal. retourque RTV the oil pan gasket.. and throw it back up. watch the rear part of the oil pan as its hard to seat it well.. it took me two trys... now thats also with 4" of lift, doubt your pan will remove as easily. but i didnt even jack it up or anything.
good luck. if i can be of anymore help.. ask away.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
