Anyone running 33" tires on AWD Expeditions? - Off-Road Forums & Discussion Groups
Ford 97-current F-Series Trucks, Expedition, Excursion Discussion of all 1997 to current F-Series Trucks, Excursions and Expeditions.
post #1 of (permalink) Old 10-15-2006, 01:20 PM
TNRidgerunner
Anyone running 33\" tires on AWD Expeditions?
I'm thinking of upsizing tires on my stock suspension AWD 2000 Expedition EB and continuing to use the stock 17" x 8.5" rims. I was considering 33x12.5's or 305/70's. Anyone have experience running this or similar combinations on AWD Expeditions?
Just FYI, this is a factory full time, automatically engaging all wheel drive system that has no 2wd only setting possible. I have not researched how it works, but it automatically senses wheel slipage and sends power to the appropriate wheel. It works flawlessly now, detecting any slippage in the loose stuff and engaging the front wheels before I even feel any slippage anywhere. You have three selections possible on your dash selector switch on these AWD EB's: AWD, 4Hi, and 4Lo. For the most part it drives just like a 2wd on the road, but you can tell in some hard high speed cornering situations all the wheels somtimes are powered.
I don't want to mess up a good thing, but I do want tires a bit bigger than my 265/R70's I'm running now. I sometimes take some pretty steep and hairy dirt mountain roads/trails and bigger/grippier tires would help a good bit. Also FYI, I thankfully do not have the factory automatically load sensing suspension (airbag lifts).
Knowing anyone else's experience with this issue will greatly help me in my decision making.
Thanks a bunch in advance!
-Ridgerunner
post #2 of (permalink) Old 11-02-2006, 04:43 PM
Journeyman
Re: Anyone running 33\" tires on AWD Expeditions?
33's may be too large for the fender wells. if they do fit then check your fender well clearances. also check steering to see if it goes lock to lock and wont cut themselves on the upper part of the fender well. as for the awd, the computer should act normal and shouldnt give you any problems. keep in mind though that larger tires will give you a higher center of gravity and adversely affect handling. reactions for both you and the computer will be slightly slower. you mentioned high speed cornering, see if the new tires have a larger footprint then the stock ones, usually they do but you never know.
TNCowboyPRCA is offline
post #3 of (permalink) Old 10-26-2009, 06:16 PM
Newbie
The 4AWD system on these trucks senses rear wheel slippage and engages a magnetic clutch to go 4WD. My truck has the same setup. There is a way to mod it so you can have regular 2WD, but I have not tried it.
I run 285/75/16 (approx 33x12x16) with very minimal rubbing, and only on the trail. The fronts used to rub that little lip on the front bumper at full lock, and it was busted anyway, so I took it off. The inner corner of the tire will rub on the frame a little, but not until about 3/4 travel. The wider tires you are considering may rub more than my 285s do. Here are a couple pics. In the last one you can see where the rear tires rub the frame during travel.
poppa wheelie is offline
post #4 of (permalink) Old 10-26-2009, 06:30 PM
Novice
It is a pretty simple job to cut the wheel wells and fender wells. The Ford Expeditions, Explorer and Escapes all have great patterns to follow on the fender itself. JC Whitney and many other company's make fender extension replacements for the Fords that are pre-made to clip, rivet or bolt right on. they also carry a replacement wheel well as well.
PhilVV is offline
post #5 of (permalink) Old 03-25-2010, 09:54 PM
Newbie
the 33s will be just fine, i was running 32s on my expedition stock and i wheeled it hard, just stay in the wells, dont go over 10 wide and you will be fine, i recomend 33/9s they are narrow, but will not give you any problems this is stock on 32 super swampers,
dgray69 is offline
post #6 of (permalink) Old 07-23-2010, 03:27 AM
Newbie
If you drive with 33" you have to give an extra lift to your car nearly 2" lift kit will do this job or else the tires will rubbing all over the bumps.
mikesheldon is offline
post #7 of (permalink) Old 07-24-2010, 02:55 AM
Newbie
Yes I feel that for 33 you will need an extra lift. I have a ford explorer which I have lifted.
gaush007 is offline
post #8 of (permalink) Old 12-18-2011, 05:05 AM
Newbie
I drive 33x12.5x17 on stock rims and without a lift...
Only a little modifikation on the airride an that was it....
omegalita is offline
post #9 of (permalink) Old 11-16-2013, 09:23 AM
Newbie
DetroitDarin's Avatar
I run 295/70/17 trail grapplers; almost 34" - but I have a 3/2 spacer lift. Here's it compared to a stock expy
DetroitDarin is offline
Human Verification
