i want to paint my truck (1990 f-150, 6" susp. lift, 36" TSL's)i dont want to paint it gloss black because im gonna put a ton of scratches in it on the trail, ive seen vehicles around in a matte black color, almost like a black primer, how could i achieve the matte black look with the most durability possible and fairly cheap?
cans are 98 cents apiece at wal-mart... flat black isnt as hard to get to look right as the glossy colors are. good luck, i would grab several cases instead of individual cans [img]images/icons/wink.gif[/img]
You can get some hi temp engine or header paint.Go with the fan motion left to right stay 12in from body off the truck.
Oh don't let your finger tip overlap the nozle you will get the runs . Do it in a well ventilated or you may get lite headed and pass out
flat black will 'show' scratches more then gloss paint.
I had a railbuggy that i painted olive drab (it use to be gloss yellow). when it was gloss yellow it did not show the scratches near as bad. you could see the scratches from across the street after the drab was applied.
