ignition cylinder 91 bronco - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > Ford > Ford 67-96 F-Series, 78-96 Bronco
Old 07-28-2000, 10:45 AM
Default ignition cylinder 91 bronco
I have a 91 ford bronco and the ignition cylinder is locked up tight.Put in the key and I get chime but can't turn it to start the truck.So, I bought a new cylinder to put in but in the locked position I cant change it.Do I need to drill out the pin which holds the cylinder in?Is there a way to get the cylinder to unlock?Please help!
Old 07-28-2000, 12:42 PM
Default Re: ignition cylinder 91 bronco
If you can't turn it you will have to drill out the pin.
[img]/wwwthreads_images/icons/cool.gif[/img] MG48 - 88 Bronco
Old 07-28-2000, 09:55 PM
Stranger
broncsweet is an unknown quantity at this point
your better off drilling out the cylinder and tumblers (keyway) I believe the pin your refering to is hardened steel. The column is made of aluminum and Which if drilled will go easy and then the column will be junk. I did one once with a locksmith in an 84 it took us about an hour. you have to have the key turned foward to get the pin to retract to remove the cylinder.
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
