ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Ford > Ford 67-96 F-Series, 78-96 Bronco
Old 10-02-2005, 11:39 AM
esm esm is offline
Journeyman
esm is an unknown quantity at this point
Default Why does my Bronco need premium gas?
Hi,
I have a '96 302 Bronco. For several years now I have to buy premium gas because everything else causes it to ping badly under load (uphill).
I have replaced the plugs, wires, cap, rotor and I have checked the timing, which is exactly at 10 degrees (original factory setting). What else could be done to get back to normal gas?
Thanks,
Ed
Old 10-19-2005, 01:21 PM
kemicalburns
Default Re: Why does my Bronco need premium gas?
when you adjust the timing it must be done with the spout connector removed. i would also scan for codes , could be something else wrong and you may also have a vacum leak somwhere
Old 10-19-2005, 05:30 PM
Journeyman
agin2000 is an unknown quantity at this point
come again? (spout connector removed) whats spout connector and why it most be removed on timing adjusting????
Old 10-19-2005, 10:04 PM
Stranger
2facedbronco is an unknown quantity at this point
Removing the spout connector sets the truck into base timing. So the computer is bassicaly out of the loop (no advance) You then adjust the base timing like normal with light/distributor adjustment. Then plug the spout back in.
  #5
Old 10-19-2005, 10:06 PM
Stranger
You may have carbon deposits in your combustion chambers causing hot spots under heavy load. How many miles are on the motor?
  #6
Old 10-20-2005, 04:26 PM
Journeyman
wheres the spout connection?
  #7
Old 10-25-2005, 12:42 PM
esm esm is offline
Journeyman
I did disconnect the spout.
The engine has 310k miles on it.
  #8
Old 11-16-2005, 02:13 PM
kemicalburns
try running some seafoam thru it. you may have carbon build up inside the heads causing an increase in compresion ratio. that is a lot of miles on that motor and i wouldnt trust the timing marks or the timing chain either. i am willing to be one of the to have slipped giving you a false reading.
  #9
Old 11-22-2005, 11:28 AM
esm esm is offline
Journeyman
What's seafoam?
As to the timing chain, I don't think it has slipped. The gas mileage and overall perfomance, which is quite good considering the 310k miles on the engine, would be noticeably impaired.
  #10
Old 12-09-2005, 01:49 PM
havack's Avatar
Pooh-Bah
havack is an unknown quantity at this point
Google seafoam and you will find out all you need on it. You might try and retard your timing a bit to cure the ping. Some Fords are known to want the expensive gas.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
