power window switch problem.............NEED HELP - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-13-2005, 05:04 PM
broncoryder88
1989 Bronco full size, passenger window only works when tapped with a hammer. Switch is ok, I think. Pulled motor out and it worked as it should. Soon as I put it back in, it will work a few times then go dead. Till I tap it with a hammer.
Anyone know if this common, and what would the cure be ?
thanks in advance for help !!!
post #2 of (permalink) Old 06-14-2005, 03:19 PM
Re: power window switch problem.............NEED HELP
not a 100% sure but could it be grounding out or mabey trying some electric cleaner in the connections
-=Azo=- is offline
post #3 of (permalink) Old 06-15-2005, 06:16 AM
Aprentice
sounds like the window motor armature has a parcial open or high resistance. It works ok w/ no load, but as soon as you make work hard,amp draw goes higher then the armture can handle. Placeing a hammer head next to the feild increases the magnetic field giving a small boost. Smacking it w/ a hammer may cause the open to close for a sort time. Either way the motor is bad.
Wes
JWharden is offline
post #4 of (permalink) Old 03-02-2011, 06:52 PM
Newbie
Quote:
Wes
I know this was ages ago, but the same thing happen to my ford power window switch. Last day, i have checked the hammer and seems that it also increases magnetic field. Any update on this one?
travisman is offline
Human Verification
