Power steering hose connections. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-21-2005, 09:17 PM Thread Starter
nathan_in_wa's Avatar
Hi guys, building a tough truck and useing a really tall style Ford steering box that is marked 77 Ford pickup. There are 2 ports, a 5/16 and 3/8 invwerted flare. I am needing to know wich one is pressure and return.
Thanks for your guys time.
Nathan
nathan_in_wa is offline
post #2 of (permalink) Old 03-21-2005, 09:24 PM
curtcon
Re: Power steering hose connections.
I would think that the presure would be the bigger one but not shure.
post #3 of (permalink) Old 03-26-2005, 07:58 PM
Novice
dammitman's Avatar
Hello,
The return is usually larger than the supply to avoid "choking" the system. Consider this, if you were to eat two pizzas a day but could only "discharge" one per day sooner or later you would back up and shut down. To have the capacity to process food the passage must be clear.
Hydraulic systems are no different; they use fluid to aid in the actuation of a device. Since it is a closed system the discharge is sent to a sump for reuse. The supply side of the system relies on pressure were the return side must move the fluid as fast as possible so velocity is paramount, hence the larger diameter; it is more important that fluid is available.
Once the fliud has completed its task (steering the vehicle) the fluid must be recycled as quickly as possible. The larger the diameter the larger the flow rate and the quicker it can by reused.
dammitman is offline
post #4 of (permalink) Old 10-11-2010, 09:21 PM
Banned
its a tough question when it regards to power steering hose connections but in case you need a new one i think i can help.
princecasanova is offline
Human Verification
