ignition coil arcing - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-10-2003, 08:28 PM
racemedic
The other night I was looking under the hood with the engine running and I noticed that there was arcing around the coil. I have a MSD 6A with the TFI coil and plug wires. I didn't see any arcing from the wires just the coil. Any ideas on how to fix this or is this an indication that the coil is going bad on me.
Thanks
-Bob
post #2 of (permalink) Old 10-11-2003, 02:31 AM
BigNorm's Avatar
Re: ignition coil arcing
Where is it arcing from on the coil? Is the coil wire ok? I've never heard of arcing from the coil itself. Is it arcing from the terminal???
BigNorm is offline
post #3 of (permalink) Old 10-11-2003, 08:19 AM
racemedic
It's arcing from around the sides. If you are looking down at it from the front you can see arcing on both sides from the coil itself to the bracket that holds it in place. I have never seen this before either. I guess I should have given this info before, '93 Bronco with a 5.8 and E4OD.
Thanks
-Bob
post #4 of (permalink) Old 10-11-2003, 12:54 PM
BigNorm's Avatar
I've never heard of that either but I'm thinking Bad Coil! Bad! It sounds as if this can turn into a personal electrifying experience if you are not carefull. Call the company and ask them why it may be doing this. Tell them you are a member of a highly prestigious offroading community [img]images/graemlins/grin.gif[/img] and that you will let everyone know what a great company they are if you can exchange it for a new one. [img]images/graemlins/smile.gif[/img] Take Care. NORM
BigNorm is offline
post #5 of (permalink) Old 10-11-2003, 02:39 PM
86convert4wd's Avatar
Too much resistance in the wires or a gap thats too big will blow thru the side of a coil. If a coil can't spark it will build voltage untill it can and if it has to blow thru the side of a itself to release the energy it will. Go over the whole ignition system before replacing the coil to make sure you don't ruin another one. Good luck
86convert4wd is offline
post #6 of (permalink) Old 10-13-2003, 01:09 PM
BigNorm's Avatar
[/ QUOTE ] Good to know. This is why I log in here daily. I learn something new all the time. [img]images/graemlins/grin.gif[/img]
BigNorm is offline
post #7 of (permalink) Old 10-14-2010, 02:16 AM
Banned
Change your spark plugs, your wires, cap distributor and rotor. I'm pretty sure your problem is there.This just happened to me. Before you change your plugs, wires, and cap, try this first. Pull the cowling engine cover off, locate the ignition coil and try to start the engine. Look at the coil and check for arcing. Race the engine a little to see an arc. I replaced the coil, and the problem was solved.
__________________________________________________ _________________
MR GASKET IGNITION COIL COVER, CHROME, UNIVERSAL -- Made from steel; Will fit most horizontal mount ignition coils; Includes chrome plated mounting bracket
krislou80 is offline
Human Verification
