My radiator wont drain. What to do? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-05-2002, 01:37 PM
I went to do a few things to the bronco today. I was going to drain and flush the coolant and replace the thermostat. I put a hose on the radiator drain valve and tried to turn it on. The valve turned no problem but nothing came out. I took off the radiator cap to see if the vacuum was keeping the coolant in but that didn't help either. What could be the problem? Just a jamed valve?
I could have taken off the lower radiator hose but I didn't want coolant spilling all over the place. (I had already spilled enough trany fluid.)
P.S. I was also going to replace the t-case fluid but the fill bolt there is stripped. (good thing I didn't drain it before checking) Any garage should be able to drill that out and replace it right?
post #2 of (permalink) Old 10-05-2002, 08:33 PM
Re: My radiator wont drain. What to do?
Not sure what to tell you on the radiator, but I'm sure that the fill plug could be drilled and taken out with an easy-out if it's not not frozen up too tight. You can get an easy out at most any parts store or hardware store. Just make sure you use the right size drill, and turn the easy out nice and slow and in the correct direction...I've made that mistake before [img]images/graemlins/wink.gif[/img]
CJ7Attitude is offline
post #3 of (permalink) Old 10-05-2002, 08:54 PM
Carpal \'Tunnel
You are speaking of the drain cock on the radiator right? that is what's stuck? Try some penetrating oil and get that thing to come free. since you are going to all the trouble, thermo and everything, make sure you flush it our real good. And, I have never been able to figure out how NOT to spill a bunch of coolant all over the place. I try, but it just isn't happening.
Mary Kate, you have NOT filled out your bio!!?? [img]images/graemlins/tongue.gif[/img]
I was going there to see what year/tcase you might have, but I am out of luck. Is your fill plug a square holed plug? Aluminum Tcase? Hate to see you spend money on someone doing this when you may be able to get this out yourself. [img]images/graemlins/laugh.gif[/img]
TheJuice is offline
post #4 of (permalink) Old 10-05-2002, 09:55 PM
muddybronco's Avatar
no, it sounds as if the valve is open but the drain is corroded shut... try shoving a coat hanger up there maybe? dunno... can't think right now, we're at 5th overtime, at this rate we'll beat our 7 OT record from last year [img]images/graemlins/wink.gif[/img]
errr, make that 6th [img]images/graemlins/shocked.gif[/img]
muddybronco is offline
post #5 of (permalink) Old 10-05-2002, 10:20 PM
Steve83's Avatar
If your coolant is dark or unusually red, you've probably got a radiator full of rust that's clogging the whole bottom. Try warming up the engine (thoroughly) and then rinse the radiator while holding the fan stopped. (The clutch will let you. [img]images/graemlins/smirk.gif[/img]) Watch how the water dries - if only the top dries immediately, you'll be able to see exactly how far up the core is packed with sludge because the packed area won't have any hot coolant inside to evaporate the water on the outside. I once spent 2 hours trying to flush one out before finally buying a new one. When I cracked open the tanks, some of the sludge was DRY! [img]images/graemlins/shocked.gif[/img] That gives you an indication of how solidly packed it was and how long it had been that way. [img]images/graemlins/frown.gif[/img] I had the idea to try to flush it when the drain valve didn't work... [img]images/graemlins/blush.gif[/img]
Steve83 is offline
post #6 of (permalink) Old 10-05-2002, 10:21 PM
That is what I'm talking about. But it's not stuck (kind of). I can turn the 'wingnut-shaped handel' no problem but the fluid doesn't come out.
[/ QUOTE ]Done
[/ QUOTE ]Yes the fill and drain plugs on my t-case are both 'square holed' plugs. Except the fill plug is a 'circle holed' plug (stripped out the wazoo).
post #7 of (permalink) Old 10-05-2002, 10:27 PM
If your coolant is dark or unusually red, you've probably got a radiator full of rust that's clogging the whole bottom. I had the idea to try to flush it when the drain valve didn't work...
I deffently have rust in my coolant. You are probally correct about it cloging the valve. When I turned the valve on not even a drop of coolant came out.
Replacing a radiator sounds somewhat complicated. Should I not worry about it because the winter is approching? I don't think my engine can overheat in a Vermont winter, even with no radiator.
post #8 of (permalink) Old 10-05-2002, 10:59 PM
Journeyman
replacina a radiator isnt too hard, and even with winter coming itd be a good idea to do it if you cant flush out your clog
kortam is offline
post #9 of (permalink) Old 10-05-2002, 11:15 PM
Carpal \'Tunnel
Now that you started you better finish. Sounds like the radiator is major plugged. Note that Steve spent 2 hours trying to unlug and then bought a new one. So, I suggest you pull the hoses and get the radiator out. It really iseasy to pull from the truck. Sould take about 1 hour. examine, and have a new one handy. If it is that clogged, do not put a new one in until the thermostat is replaced, it has been flushed throughly, maybe new hoses, and then new coolent. The green stuff, no other.
Someone mentioned an easy out. You can do this. It is just a drill bit kinda deal (you have a drill?) basically the idea is drill a small hole in the messed up plug, screw the easy out in (I believe it screws counterclockwise) and by screwing it in, it screws the plug out by force. (easy out tighens via counter clock, which is loosen for the plug) Be careful if you are working with aluminum!! Torques, etc, are less with aluminum.
TheJuice is offline
post #10 of (permalink) Old 10-05-2002, 11:55 PM
Sixlitre's Avatar
Location: Iqaluit, Nunavut Territory, Arctic, Canada, now Ottawa, Ontario Canada
A rad shop can boil(hot tank) old style brass rad, but I don't know if they can do much for the newer plastic header tank types.
It is important to fix before Winter. Even Vermont gets warm days and you can fry/boil the back few cylinders enough to crack a head or blow a head gasket. Also I'd assume you'd be interested in the heater working better this Winter too.
Sixlitre
Sixlitre is offline
Human Verification
