OBDII no power to port - Off-Road Forums & Discussion Groups
Go Back   Off-Road Forums & Discussion Groups > General Off-Road > Electrical & Wiring Tech
Old 06-03-2014, 10:07 PM
bowtie4by's Avatar
Newbie
bowtie4by is on a distinguished road
Default OBDII no power to port
There is no display on my OBDII when it is connected to the port, and emissions had the same issue. I failed due to that. I checked fuses and all are good visually. Any ideas why there is no power to the OBDII port in the vehicle? How fix it?
__________________
Been on off-road.com since 2001.
G65 shocks are evil!
Boycotting Castrol for calling their Type III Syntec oil "Synthetic"; Boycotting Mobil1 for changing most of their bases to Type III and refusing to admit. Royal Purple identifies PAO/Type IV as their base; Red Line IDs Group V/ester as base. G80=Gov-Lock=>Locker,auto (not Limited-Slip)
Old 06-17-2014, 04:51 PM
bowtie4by's Avatar
Newbie
Default No power to OBDII port
What about running a jumper from the cigar lighter to the power wire of the port? It looks as if the wiring diagram shows they are on the same circuit.
__________________
Old 06-26-2014, 03:35 PM
DezertScorpion's Avatar
DezertScorpion is an unknown quantity at this point
Default
Hello bowtie4by,
On your GM truck, the cigarette lighter fuse also powers your OBDII port. Check the fuse box for CIGAR fuse. If it's blown, swap it with the proper auto fuse. Even if it looks good, test it with an ohm meter, or simply exchange it with a good one. Sometimes this fuse gets overloaded with gizmos attached to the cigarette lighter and will blow. Your OBDII port should be good again once you resume power.
Test at home with your own OBDII scanner before taking it into the smog shop again.
Good luck!
__________________
DezertScorpion
Old 08-24-2014, 07:46 PM
bowtie4by's Avatar
Newbie
Default
Thanks DezertScorpion! I ran a jumper from a 10amp accessory to the back of the OBDII port and it works. When I brought the Tahoe to emissions, the bastages failed me due to a wire powering the port. I'll replace all the suspect fuses with new ones next. Thanks for the help.
__________________
Location
Where you live
Primary Off-Road Vehicle
Secondary Off-Road Vehicle
Biography
A few details about yourself
Interests
Your hobbies, etc
Occupation
Your job
Insurance
Date of Birth
Month Day Year
Privacy
Human Verification
