I have a business building and overhauling off road transaxles and there are 2 primary causes that we see for chronic leakage at the wheel. The most common is damaged or incorrectly installed parts. You need to have a quality axle seal kit with "o" rings, seal, and shim, your seal race must be in good condition, and the parts must be installed in the right order. Our web site at
www.transworks.biz has a section called "installation help" that explains the procedure with pictures. The second most common problem is a bent axle tube. I've talked to so many customers who are frustrated because they've replaced all the related parts over and over and still can't stop the leak. Put a straight edge on your axle tube and a square between the tube and the end casting. If the tube is bent the axle is running through the seal at an angle, and you can install all the seals you want and it will still leak. If everything checks out ok and you still have a problem feel free to call us anytime for advice at (619)441-0133
