ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Sandsport Forums > Dune Buggies, Sand, Desert Cars
Dune Buggies, Sand, Desert Cars Discussion of Dune Buggies - Sand, and Desert Cars. Generaly of tube construction
Old 04-10-2002, 04:55 PM
Trackball
Default how to make a baja bug long travel?
ok well im new to this and i keep seeing sites talk about having 18" of wheel travel or more on a baja. How is this done? Where can i get long travel kits/ how do you fab up some of this stuff. what are good suspension sites?
Old 04-11-2002, 11:09 AM
VORRA#65
Default Re: how to make a baja bug long travel?
To get that kind of travel, you have to make a number of mod's or combination of mod's.
longer and wider arms front and rear
notch springplates-rear
grind the springplate rest down to allow more droop-rear
don't run torsion bars-go to coilovers in the rear
Those are probably Class 5 unlimited cars, that are getting 15+ inches of travel.
Some of the 5/1600 class cars get up to 12-13" in the rear, running torsions.
Old 04-12-2002, 03:37 PM
Trackball
thanx for the info. I'm buying my baja soon (the next month or so). I want to find out as much as possible before I buy it. I don't know what year it is so that limits my searching for suspension related stuff. It's going to be all off-road and if it doesnt already have coil overs it will soon. I do know it has an 1835cc dual port/dual carb engine. I hear they have problems over heating but it doesnt get too hot here so I should be ok. I'll be doing as many cooling upgrades as possible. Any suggestions?
Old 06-09-2002, 08:23 PM
from all that i have seen.... the largest iv seen pulled with a link pin setup.... 13 inches is teh max... un less it is a a-arm front suspension.... im probubly wrong but i thought id just put in my 2 cents.
  #5
Old 09-29-2009, 03:50 PM
writeforus's Avatar
writeforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORCwriteforus has a brilliant future at ORC
Default
So Trackball, it's been a couple years - are you still around? What did you end up doing with this project?
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
