dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Dodge 4x4 vehicles All discussion of Dodge trucks, Ramchargers, Plymouth and SUV's... |
06-19-2008, 07:44 AM
|  | Veteran | | Join Date: Mar 2003 Location: York,SC
6" of BODY lift is a death wish. I would think the body would separate from the frame under moderate-heavy braking. The farther the body and frame are away from each other, more leverage is placed on the mounting points, thus causing something to break/bend. Even 3" is excessive,IMHO, and may affect airbag deployment in an accident. Just my .02...
06-19-2008, 03:55 PM
Thanks tomkat..
so what could i do to make my truck a little higher?
Would just buying bigger wheels and tires be my only, safe option..
cause right now my truck handles awesome. it drives just like a sports car. so i don't want to substitute that just for the lift.
would that lift kit i posted below be safe?
06-19-2008, 09:35 PM
| | Quote:
Originally Posted by yoblum20 would that lift kit i posted below be safe? | ? Which one? Body or suspension? IFS suspension lifts can get complicated with cv angles and alignment angles at times.
06-19-2008, 11:37 PM
| | | Quote:
Originally Posted by TomKat ? Which one? Body or suspension? IFS suspension lifts can get complicated with cv angles and alignment angles at times. |
I was looking at a body lift... it is just 2" or 3" blocks that you put between the body and frame...
but if these aren't safe what other way would i have to make the truck a little higher?
06-20-2008, 07:36 AM
Oh, OK. I'm sure plenty of testing was done before it was made available. It will help out plenty with tire clearance, just not any off road benefit other than larger tires. Just try to get brackets to raise bumpers as well or they look kinda corny hanging low...
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 07:12 AM. |
