ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Dodge 4x4 vehicles
Old 12-12-2007, 06:07 PM
Phrog
Default To re-gear or not to re-gear
I own a 2005, 2500 4x4 with the Cummins power plant and 3.73:1 gears in the axles. It is also equipped with the 48RE transmission. I’m putting a lift kit on it and larger tires (35”). I’ve had several people tell me that with the diesel, I will not notice that much of a performance drop off from stock. I’m looking for info from those that have put bigger tires on their truck and what the performance was like after the new tires compared to the OE 31” tires.
Thanks!
Old 12-13-2007, 09:00 PM
Novice
DODGEBOYS is on a distinguished road
Default
even with a GAS motor you dont notice it that much but on hills / BUT not with the DIESEL / it has plenty / 3.73,s are about right for 35,s anyways / it should be 4.10,s for MAX power / but with the 3.73,s you,ll do better on the hiway
Old 12-15-2007, 07:53 PM
Phrog
Default
Thanks for taking the time to respond!
Old 12-19-2007, 11:39 PM
80powerwagon
Default not to re-gear
i have an 03 cummins with the same gears and i run 315-70-17 or 35/12.5 17s. i have to switch to factory tires to pull my camper around and i do notice a power difference when i put the big tires back on, but not enought to really worry about. the banks six gun more than takes care of that. with those tires and gears i get 20 to 25mpg on the highway. really really like the set up.
  #5
Old 12-20-2007, 12:03 AM
Phrog
Default
Thanks for the info...has the installation of the Banks gear presented any problems with the functioning of the engine or transmission?
  #6
Old 12-20-2007, 08:43 AM
80powerwagon
Default
the banks is the best thing ive put on my pickup. i have had zero problems with the engine or tranny. you can pull on the number six setting because the torque converter will sense a little slip and shut the banks down. so six is just for play. other than that its pretty sweet. you definately need to upgrade you exhaust if you put one on though.
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
