ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Dodge 4x4 vehicles
Old 03-12-2007, 10:52 PM
74PowerWagon
Default 1974 Early Dana 44
Hello all, i just recently picked up a 74 dodge powerwagon that has had a problem with front wheel studs, finally got the lugs drilled out to find out the the previous owner had welded in grade 5 bolts and washers to hold the wheel on, i however am going to have new studs installed but have run into a road block. i have the lockouts off and was just wondering if the spindles (not sure if its the spindle, but the piece with the studs pressed into it) are pressed in or if they should just pull off? its and early 74 with drum brakes and is not a full time 4x4 rig.
Old 03-14-2007, 11:33 AM
Novice
DODGEBOYS is on a distinguished road
Default
the studs are swedged/crimped in / just beat them out with a hammer
Old 03-14-2007, 07:20 PM
74PowerWagon
Default
Sorry, i didn't mean the studs themselves, i meant the piece the studs are press into? im not sure what you call it, but is it pressed onto the spindle?
Old 03-15-2007, 12:30 PM
Novice
Default
theres the steering knuckle and the spindle thats bolted to the knuckle that the wheel bearings ride on / its held on the knuckle by 6 nuts / use either a brass hammer or mallet or a 4x4 block of wood an a BFH
Off-Road Videos -
ATV Reviews -
Axxxtion Sports.....
