ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Other Vehicle Specific Forums > Dodge 4x4 vehicles
Old 12-24-1999, 01:21 PM
Default Leveling 1998 1500
I have a 1998 1500 QC long bed 4X4... I was wondering if anyone had a "quick fix" to level the front end with the rear?? Spring spacers?? New springs?
Thanks in advance!!
Old 12-25-1999, 06:56 PM
superswamper's Avatar
superswamper is an unknown quantity at this point
Default Re: Leveling 1998 1500
Yes, there is a way...National tire and wheel sells a product called: daystar poly spacers, it is a 2" polyurethane spacer that mounts on top of your existing coil springs, according to there catalog.
I bought them for my 95` 2500 to get a lttle more room for bigger tires with an existing 5" lift. They cost just under $200. I have yet to install them though, but hopefully soon...
1-800-847-3287 national tire
Old 12-27-1999, 12:04 AM
Just a comment... If you're successfull with raising the front to match the rear, when you put 1000 Lbs. in the bed, it will be down in the rear, rather than level. And as you approach 2000 Lbs., it will look like a speedboat under full throttle! Pickups are up in the rear unloaded for the obvious reason. SUV's, on the other hand, tend to be level (don't see too many SUV's carrying refrigerators, dirt, gravel, much of anything with weight).
If you don't plan on carrying anything, well, OK.
Off-Road Videos -
ATV Reviews -
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
