ram 360 burning oil questions(long)
I have a 96 ram 2500, 5.9 gas, with about 100k miles, now i have been noticing some oil consumtion more so than normal, the truck seems to have plenty of power towing out 8500 lb trailer, i havent really noticed any loss. but the real problem occours in 2 situations, when it sits and idles for like 15 minutes or so long enought to load horses or say a tractor, then when i go to take off it smokes alot, like not a wiff but like the rings are gone, smoke everywhere, but then i can throw it in neutral, rev it a few times til it clears up and then it is fine, now i seriously doubt that oil pressure is dropping since it has never at stop lights or anyother time it idles, also when ever i am going down a mountain and i have geared down to stay off the brakes, after like 5 minutes it will smoke awefully, until i use the brakes or gass it and go on. i would think this is the valve seals but i have never replaced them on a mopar so i wonder if it is the same proceedure as a chevy or ford. also does this sound consistent, i have true duals with no cats, and it is considerably more noticeable on the right 4 cyls, so bad it will soot up the front of the horse trailer when it does it. thanks soggysod
