dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Dodge 4x4 vehicles All discussion of Dodge trucks, Ramchargers, Plymouth and SUV's... |
07-01-2002, 01:35 PM
|  | Keyboard Implanted | | Join Date: Mar 2001 Location: Altamonte Springs FL
| | Power waggon questions.
Afternoon, a friend of mine has bought a 76? I think dodge power waggon and he's got some work to do. Is a 360ci engine common? The rear axle, is that a D44? It's not a floater rear so I think it is a 44. Are there axle breathers? The x-fer case, are they np205 cases? Has anyone done an external transmission filter modification (water, dirt, mud [img]images/icons/laugh.gif[/img]). Anything I should look out for or change/replace/mod immideatly?
Thanks
07-02-2002, 06:46 PM
| | Re: Power waggon questions.
also, do you know where the engine casting numbers would be? I need to id an engine for the rear seal (stock engine is not the correct one that we need). |
07-02-2002, 06:58 PM
| | Enthusiast | | Join Date: Aug 2000 Location: TEXAS
| | Re: Power Wagon questions.
If it is a 1976 Power Wagon, then these motors apply:
318, 360, 400, 440. Small Blocks have Dist in rear, BB have it in front.
Front Diff. should be Dana44 look on webbing for ID.
Rear Diffs. that were available are as follows: 8 3/8 D100, 8 3/4 D100 & W100, 9 1/4 RC & TD, Dana 60, Dana 60HD full floating D200 & W200.
Tranny (if Automatic) should be either a A-345 (74-76), or a A-727 (67-88) Identification pad is on the right side of the tranny.
Transfer case could be a NP-205 (1974-1976) or NP-203 (1977-1979).
According to "Chilton's", hope it helps. |
07-06-2002, 09:51 AM
Much appriciated. I'm planning on twin sticking the 203 x-fer case [img]images/icons/laugh.gif[/img]. The transmission has been removed and I've verified the engine is a 360 SB. Thanks for the locations on the transmission, I'll have to check out the rear and front axles to id them. There is a "9" stamped on the lower pinion webbing on the rear, Corp 9"?
Thanks again.
ps. those 203's are frekin heavy!!!
07-07-2002, 03:03 PM
Erm, No Corp stuff in Dodges, that I am aware of... That's a CheBBy thing..
The "9" may be part of the 9&1/4 Stamping.
Get yourself a $13.00 Chilton's Manual on "Dodge/Plymouth Full Size Trucks, 1967-88 Repair Manual" part #8662. You should be able to get one at your local parts house. Really good Info in it and pics of the various things you need to see, to identify with, Torque Spec Charts, etc.
Helps me out EveryDay. | | Thread Tools | | | | Display Modes | Linear Mode |
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 06:42 PM. |
