Kanati Terra Master - Now you can maximize your performance by customizing your tire set up!
GBC Motorsports is proud to bring you the industry's first UTV tire with an asymmetrical non-directional tread pattern, the Kanati Terra Master. This specially designed tread pattern gives you the benefits of two tires in one. With two distinctive sides to choose from, you can customize your tire set up to your vehicle application, and your driving style.
Side A - Recommended mounted out for soft to intermediate terrain
Side B - Recommended mounted out for intermediate to hard terrain
The carcass profile is optimized for forward traction and side bite, all while having a lightweight steel-belt construction. The Kanati Terra Master is the next level of performance for today's high-performance side-by-sides, proving once again that GBC is a leader in innovation for the ATV and SXS Markets.
Click here for Kanati Terra Master Availability & Pricing online through Discount Tire Direct.
Also available in store by special order HERE
-KEY FEATURES-
*content provided by gbcmotorsports.com
-KEY FEATURES-
- Steel belted radial design for stronger core and greater wear resistance
- 10-Ply Rated Construction
- Asymmetrical tread pattern for dual benefits and performance characteristics
- Meets and exceeds DOT standards
- Designed to combat a wide variety of terrains and conditions
- Non-Directional design for excellent responsiveness in any direction
- Powered by years of research and field testing
