| Dirtbike Lounge Hang out and talk two wheels. For Tech and Racing specifically, see those forums below. |
is there such thing as bleeding the air outta forks on a mx bike? if so how often should it be done? I RIDE A 00 YZ250! YES IT IS FAST! NO YOU CANNOT RIDE IT! |
| Sponsored Links | ||
Advertisement | ||
I have a'00 YZ250, and yes there is an air bleed screw at the top of the fork tubes. It's the screw off to the side on the cap. I can't seem to find any instructions in my '00 manual, but I recall from my old bikes manual, you loosen that screw, compress the forks to squeeze out any air, then tighten the screw back. Sorry I can't find the actual print. If you can get access to a Clymer manual, it has a detailed procedure on bleeding air out of the fork tubes. Normally you shouldn't have to do it very often, unless you are changing the springs or the oil in the tubes. RoosteR I love the smell of two-stroke in the morning..... |
i know this isn't my post, but i have a question of the same concern, do you tighten the screw back up with the forkes down, or keep pushing the forks down until the air quits coming out then tighten them up. Thanks Rooster. Marc 88 Samurai, 16 V EFI motor, Dana 44's, 36" Swampers, ARB and Detroit lockers, custom drop arms, GRS II, 5.38 r&p, Warn 8000, custom bumpers, leather seats & lots more. |
just unscrew it! it will go tiss ssst thats it. no need to compress. tighten back up. it when you use your bioke alot and air gets in through the seals and builds up. just like a manual blow off valve. loosen, let air out, retighten. as easy as flapjacks |
#5
I had an RM250 and it said to put the bike on a center stand to get the front tire off the ground, then remove both screws and retighten them. I do the same thing with my WR426, about once a month or when I change elevation to go riding. Tom |
#6
the reason i beleive that they tell to raise the front forks off the ground is so the oil doesnt come out. in case they are slightly compressed or your oil level is high |
| Sponsored Links | |
Advertisement | |
« Previous Thread
Next Thread »
| Thread Tools | |
| Display Modes | |
