Jeep JL Wrangler Switchback Turn Signal LEDs
With this kit, you can convert the front end of your 2018 Jeep JL Wrangler to an all-LED, cool white modern appearance. This kit fits Sport models, and trim levels not equipped with the LED Lighting Package.
At Diode Dynamics, we carry a full line of LED bulb replacements, including these unique dual-color switchback LEDs! Our HP24 is a unique design, and the brightest available on the market, designed by our engineering team in St. Louis, Missouri.
Click to order or for more information:
Diode Dynamics: Switchback Turn Signal LEDs for 2018+ Jeep JL Wrangler
Diode Dynamics: Front Turn Signal LEDs for 2018+ Jeep JL Wrangler
Bulb Design:
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
HP24 Switchback:
The HP24 bulbs use 16 amber, and 8 white LEDs. They are very high-power chips. More importantly, the amber is a custom-made LED chip. Instead of a standard amber, which emits a low-energy amber light, the amber LEDs on this bulb are down-converted from blue, just like a standard white LED. It is extremely bright amber. Equipped with full aluminum body for durability and advanced digital latching circuit for color control. 6000k, Cool White to match HIDs or other LED lighting.
Included in your order is TWO BULBS to fit your Jeep JL Wrangler.
Hyperblink Fix: The turn signals on most vehicles will begin to blink fast (hyperblink) when LED bulbs are installed. This is because LEDs use less power than the original bulbs, so your vehicle thinks that the bulb is out. The JL Wrangler will not hyperflash on the exterior of the vehicle, but the indicator speed on the dash will change (See Video). This can be corrected with a basic resistor kit.
Wire colors for the JL Wrangler on both sides are:
White w/green stripe
Black
Resistor Kit: This is a universal way to fix the issue, and will work for any vehicle. By adding a resistor to the bulb's circuit, you can mimic the power consumption of the original bulb, and return the vehicle to normal turn signal speed. The installation takes 10-15 minutes, and involves making two simple connections. Everything you need is included in the kit. If you have both front and rear LED turn signals, you usually only need one set of resistors, on the front or rear, to create enough resistance for the turn signal circuit.
Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
How to Install Resistors for 2018+ Jeep JL Wrangler LED Turn Signals | Diode Dynamics
