Looking to add a fresh look to your rig's interior? Footwell LEDs are the way to do it! By adding bright LED strips under your dash, you can add a lot to the look of your rig.
Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. We have designed new LED strips to be used in this kit, which are highly flexible, IP67 waterproof, and long-lasting. This kit also uses our RGB Multicolor products, which are controlled by the included remote or Smartphone Controller (Optional Upgrade). You can change the color to fit your mood, or adjust the brightness to your preferred settings.
Included in the kit:
- 2 (two) 30-5050 SMD Strips (flexible and IP67 waterproof)
- Wiring harness for easy installation
- 2 (two) quick-splices for installation
- LED Toggle switch in your choice of LED color
- RGB Controller Box with RF sensor and 4 outputs
- Remote Control (choose Standard or upgrade to Bluetooth or WiFi)
- 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
- 3-year Diode Dynamics worry-free full warranty
- 30-day satisfaction guarantee
Also included with rear footwell option:
- 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
- 2 (two) 3-meter (ten-foot) extension wires
- Additional zip-ties and adhesive pads
Any questions email us at contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
